u1017 - ABS brake control module Read out DTC
U0428 - invalid Data Received From Steering Angle Sensor Module
U1123 - Databus error value received.
Have you done any work on your car or made any changes to the setup recently.
The only work that’s been done on my car since purchased in July of last year is a remap, brake discs and pads changed and a cat back exhaust mate, I’m assuming from the fault codes that the abs was fixed at some point as the code was red.
My cars a 14 plate
have you got VCDS or OBD11 TO Clear the faults and see if they come back or not.
If it were me I would clear the codes first and see what comes back and stays. Then try and work out what is causing the issues. Understand you have a faulty sensor on your fuel cap (guessing that is the u1123) but I would want to know what is real and needs sorting.
