MrJohn91
136
63
www.facebook.com
I have applied the below coding to my Leon but it seems now that the red does not light up at all (unless it is exceptionally dark) and then when you indicate the white light flashes, 2 questions, why doesn't the red work and (not as important) can you have it white and flashing red when you indicate? I've put my history from OBD11 below (n.b. I haven't done the Dimmwert options as these were already set to 0)
Hopefully I've made some sense...
Updated the internal lights so they flash between white and Red when indicating
With this mod, bringing the doors in red, when flashing, the door on the side of the indicator flashes between red and white.
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Select - Leuchte16BLK SLB35BLK SL KC9
4 - Submenu - Lichtfunktion C
5 - Change value to Blinken links (beide Phasen) BOTH SIDES OF INTERMITTENT or Blinken links (Hellphase) ONLY WITH INTERMITTENT LEFT
6 - Select - Leuchte16BLK SLB35BLK SL KC9
7 - Submenu - Dimmwert CD
8 - Change value to 0
9 - Select - Leuchte16BLK SLB35BLK SL KC9
10 - Submenu - Dimming direction CD
11 - Change value to Minimize
12 - Select - Leuchte16BLK SLB35BLK SL KC9
13 - Submenu - Lichtfunktion E
14 - Change value to Blinken rechts (beide Phasen) BOTH SIDES OF FLASHLIGHTS or Blinken rechts (Hellphase) ONLY WITH RIGHT INTERMITTENT
15 - Select - Leuchte16BLK SLB35BLK SL KC9
16 - Submenu - Dimmwert EF
17 - Change value to 0
18 - Select - Leuchte16BLK SLB35BLK SL KC9
19 - Submenu - Dimming direction EF
20 - Change value to Minimize
21 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
22 - Submenu - Lichtfunktion A
23 - Change value to Blinken links Hellphase
24 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
25 - Submenu - Lichtfunktion B
26 - Change value to Blinken rechts Hellphase
Adaptation
Control unit: 09 Central Electrics
Name: Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
Values:
Lichtfunktion A 17:
Old value: Ambientelicht 3
New value: Blinken links Hellphase
Lichtfunktion B 17:
Old value: nicht aktiv
New value: Blinken rechts Hellphase
Mileage: 68439 km
Date: 2018-04-17 12:36
Adaptation
Name: Leuchte16BLK SLB35BLK SL KC9
Values:
Dimming Direction CD 16:
Old value: maximize
New value: minimize
Dimming Direction EF 16:
Old value: maximize
New value: minimize
Lichtfunktion C 16:
Old value: Blinken links aktiv (beide Phasen)
Lichtfunktion E 16:
Mileage: 68439 km
Date: 2018-04-17 12:35
Adaptation
Values:
Lichtfunktion C 16:
New value: Blinken links aktiv (beide Phasen)
Mileage: 68439 km
Date: 2018-04-17 12:33
on mine
Lichtfunktion C 16:
new value = Blinken links Hellphase
Do you have your light switch on Auto
On mine you only see it at night but its red all the time and flashes white when indicating,
I have attached the full set of details that i have on mine just in case there is something else that needs changing
  • leon_internal.txt
Reactions: jacko5
Managed it, it's because you can't see the red as it's too bright out, a bit of bending and now I see it. Cheers for your help there! While I have you OldBoy, on a post many moons ago you put that you'd changed
Upgraded the ABS To Increased Traction (more grip in the corners)
Removed the Torque Limiter (makes a big difference)
I've been doing some digging on the Internet and can't seem to find these 2 specifically. Can you point me in the right direction for this as well?
I will take some when its dark and put them up tonight
But its only a night time feature as during the day you don't see these lights very much
Sorry summer came today so cant find anywhere where it is proper dark so camera shows the diff.
Anyway I did the coding and then made one change so you go between red and pink (Both red and white lights are showing)
If you want to you can also make different settings for right and left turn but be aware this coding affects both doors at the same time.
Hmm think I prefer the white one only rather than pink. So if I indicate left, will the right door flash as well?
Afraid so, when you indicate both doors flash, not found a way round that yet, however you can set it up so that left and right indicator give different color or sequence but I dont even notice the flash most of the time, and to be honest it really is a night time feature.
Used your settings many thanks.
All works fine apart from when i indicate, the right the door card light goes from red to white but does not flash.
But when i indicate left it goes from red to flashing white.
Weird.
@jacko5 sorry missed this, do you want to email you settings to me and i will have a look.
Either do a backup of Control Unit 09 or just do screen dumps of the Leuchte units
