• Forum upgrade today 15th October from 3pm: Hi Guest. We are deploying an upgrade to the software that runs the forum today. It could take up to three hours. We're sorry but you're going to have to hold off on your CUPRA / SEAT fix while we work our magic. Thanks for your patience. Discussion here
Deleted member 103408
Good to know, I had to buy Bosch wipers from Halfords before i put the car in for MOT, Got the 26 and 16 but many fittings. Next time i will order in advance.
Damo H
Oct 3, 2012
4,515
2,705
Car Length In Front
If you order the Bosch A350s set it only has the correct fittings and is also the correct 26" & 16" wiper size
Any chance of a picture of the bracket on yours fitted?
Like others I got the ones with loads of fittings and due to the attachment they seemed to stick further out than the ones that came on the car. Looking at photos of that pack the bracket looks flusher to the wiper blade.
DEAN0
Old Git
Feb 1, 2006
5,440
Preston - UK
Brackets on the A350s set are identical in fitting to OEM wipers
If the site would allow picture posting without having to create a photobucket account - gladly
I can assure you the A350s fittings are identical to the OEM ones.
Damo H
Oct 3, 2012
4,515
2,705
Car Length In Front
Thanks for the heads up!
The site allows me to post photos without phitobucket, just using hr upload file option at the bottom. I’m on my iPhone at moment so not a best example:
Bristle Hound
147
49
North East Uk
Renewed my insurance :D
Just had my insurance renewal for the Cupra from, ahem, Saga, which was coming in at £367.99. An increase of £100 on the previous years quote FFS !
So after a bit of searching on 'tinterweb I've renewed with Privilege.Com for £234.08 !
Same cover as previous - Fully comp. for the good lady & I to drive, 8000/year, protected NCD, garaged & a £350 excess
Reactions: davidstarkey11
heliophile
146
39
Manchester
Finished work
Popped boot using remote
Put bag and jacket in boot
Closed boot
Boot locks automatically as usual
Realised car key was in jacket
Felt stupid
50 mile round trip to get the spare key means I won’t do this again in a hurry.
Stephenator280
112
40
In the set I bought, there were 3/4 fittings. The one I have pictured (with a number 4 on it seemed the most compatible)
Current : Cupra 280 ST
Previous: BMW 335i LCI, Skoda Octavia Vrs mk2, Honda S2000
Stephenator280
112
40
How easy was it to change the wipers? My previous car was a renault and changing anything on that was a ballache. Three arms and 5 hands needed for everything.
The process was the same as shown in this video (both the process for putting the wipers in the service position as well as undoing the blades)
IrnBru
115
22
Can someone help, today driving my Leon FR 18 plate, doing around 45mph and the car slams on the breaks for about a second, warning on dashboard and not another car in front of me, if I remember correctly I was on cruise control.
Breinholm
10
Washed it for the first time. Afterwards it was polished and wiped down with CarPro Eraser before it had a coating of Cquartz UK 3.0 applied.
I left it at the garage for the coating to cure.
Here's a picture of the result and one of the car in the wash area - it looked mean.
Damo H
Oct 3, 2012
4,515
2,705
Car Length In Front
Sorry Stephenator280, I was after a photo of the A350S. The ones you have are the ones I currently have that I changed to about 18’months ago. I didn’t like the way they stick out a fair bit more than the standard (valeo) ones.
Ordered the A350S set yesterday so should be more OEM looking :) as they needed changing anyway.
Dr.Dash
342
73
Midlands
Have a bump, rather disconcerting when automated systems trigger inappropriately.
Check the vehicle status & If you have OBD scan for faults, it'll show stored faults rather than just those which are still active.
If you have a dashcam then pull and save the footage.
Something like this is definitely worth a dealer visit even if only to have it logged. Had someone driven into the back of you as a result then it's good to have some history.
(In some cases the driver in the front vehicle can be held partially responsible for an accident, it can possibly also be interpreted as "brake testing" the rear vehicle. Not easy to disprove if they have a dashcam and you max brake without obvious reason).
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
Get the car back in the dealer ASAP as already said. Sounds like a front assist malfunction of some description.
I assume that the radar sensor is clean and doesn’t have half a dead pheasant on it?
