Thanks I will also try it in the morning and see if I get cruise control issues, @JsyCuPrA is your car facelift or pre facelift
I haven't had chance to give the direct acceleration - throttle response change a decent test yet. I haven't tried the Audi engine response but will give it a try if anyone reports a positive experience of the change.
Update Audi coding is
Select Control unit 01- Engine
Select Long Coding (1)
Select Byte 0,
Change Bit 0-2 from Seat to AUDI (02)
Cant see your picture but Bit 0, 1 & 2 are all one section, if you click on it you will see a drop down list that shows something like
SKODA/SEAT/VW
AUDI,
Just select the Audi option.
OK If you go to the HEX value (top right hand side) and change from OB to OA that will then be the same as mine
No mine was OB before I changed it.
If you change to OA you will see the bits will change below.
Yes the drop down list is how its been setup on the long coding helper. Just as a matter of interest what is the error message
Tried it on my 2013 1.8tsi manual and had no issues. Seems to be smoother and more linear.
Sent from my Pixel XL using Tapatalk
Pretty sure I saw you at Mondello earlier. I was going for the afternoon session. How did it go for you?
