ChocoMilkShark
121
7
Hi all I'm trying to work out what options I have on my car but I'm not finding it as easy as I was hoping, I have the codes but nothing to compare them too
I'll post a pic below any help is much appreciated.
e4Yag5ilNNZJ-Ptg4bHw5LGn0PTCTegp0NCLUhcLSihq3XrIfHuYV927jjJP8zYzFn65-CjuYpQfWXjru6wUmFzo8K6F2ynIl9Ry-n2hdbsO5xMmHmMSXGklSJ2MYlGynpM0rVe7zdS7LtnsUNgxTn-7wdxeg-xmywTcnoHt7VRRjDChxb2NM8t6AhOhATOmj4kSa-pB1lRf-Fr0i7L1shucRVlNPIOMX5GuCpRsS_uGIP8wIVNOEU8fW98-lGTPSsIoSrcUkStcrUkpGmT2P5Z9nbVxttwl6jAQ5pFsJ2uwuHAvN8y5ODUN9e1xp-T2W3HtObUMo3p7x9iqeWU1qfTZ5X_prlBfidKcj7fdkEiMjl0U7Fu-fmQ9dcT166alfMS3mALCh_dpqDCcQZis-qlSgPnAuSGpGP43tH-CasZ_fnnAOYHiI7ZJzoWRLKJD1pCN1ykGcp17vbOcp6U3yxlqKt6tQBERzgQqFD6YmQPCg1GHSPWvGU7RI4p2_q5Lh12rTDvU-e_oIpEhAtUlqB8owl7OOGfbYS-0_Qmd6pmbJiZHm98C2w_PZG-hWi2VHSAau0hPWHU1_9WceQR6z434r9rZ1jWFNpPbWas=w978-h1303-no
This is what I got back from looking at that list
  • X2B LDA - Equipment options subset for Great Britain
  • B0N BLB - Component parts set, complying with vehicle type for Great Britain, various parts
  • D2D MOT - 4-cylinder SI engine 2.0 l/155 kW (207bhp) 16V turbo FSI, homogeneous; base engine is TM2/TV2/TG6/TJ6/TD6/TP6/TL5/TL6/TI6
  • G0K GSP 6-speed manual transmission
  • 1AT BRS Electronic stability control (ESC)
  • 8GU GEN Alternator 140 A
  • J0L BAT Battery 340 A (70 Ah)
  • F34 RAD Alloy wheels 7J x 17
  • H6L REI Tires 225/45 R17 91W
  • 1G6 RER Space-saving spare wheel
  • 1NL RAA Trims for alloy wheels
  • 8AY RAO Radio navigation system
  • 8L6 ANT "diversity" window antenna
  • 8RM LSE 8 speakers (passive)
  • 8BK HSW Twin headlamps for driving on the left, with integrated high beam
  • 8WD NES Integrated front fog lamps
  • 8TD NEL Rear fog lamp for driving on the left
  • 4A3 SIH Seat heater for front seats separately controlled
  • 2PU LRA Leather-wrapped multifunction sports steering wheel
  • 2B2 GRD Additional exterior noise suppression
  • 5SJ ASL Left exterior mirror, convex
  • 5RQ ASR Right exterior mirror, convex
  • QG1 WIV Service interval prolongation
  • 7MG AGM Emission standard EU5
  • G51 DFV Shock absorption in front
Don't forget you also have your VIN Number, Paint Code LB9A and Engine Code CCZB
No it only shows the option codes, if you search on the web for VAG PAINT CODE LB9A hopefully you will find some results.
Same with the Engine code and the VIN Number is unique to your car and can be used on may sites to find specific parts for the car.
Also if you search what does my vin number mean there is information about build dates etc.
I went to the site direct "vag-codes.info" and it shows the engine code.
engine kw hp ltr cyl mounting time model remark
CCZB 155 211 2.00 4 05/10 - 12/12 LEON TFSI TFSI
The paint looks like candy white so nothing special, I believe that was standard.
VIN I can't find anything useful without paying so il pass on that
How badly do you want all your vehicle specific info? If you pay the 7 Euros for 1 hour's access to erWin you can get the full list for any SEAT car (providing you have the VIN).
https://erwin.seat.com/erwin/
Or ask a dealer nicely and they might print it off for you...
And just to be clear ERWIN is the VAG group official system that is kept up to day by the VAG Group fo all its garages.
That does not mean the Garages pay attention but if you want the official line on servicing etc this is the place to look.
