itsmrjt
257
20
Leicester
Anyone got any idea if this is a worth while job? Or is it more or a bling factor?
Sent from my COL-L29 using Tapatalk
Save your money. Ko4 will top out at 280 max and pushed at that. anymore wanted you should be looking at Garrett type turbo build and a built engine. 1.8t get expensive after 280 bhp mate. Very expensive.
Ok thanks.. Just as well to know what's worth while! I'm almost pushing max bar 40bhp! So maybe a subaru might give more! But for now the cupra is the one! Did you know they did a V6 mk1 cupra? 2.8ltr! Imagine that wow.. Nothing for sale tho
Wasn't sold in the uk and was the 2.9 24v lump.
Subaru..deep pockets needed.
I choose the 1.8t because parts are cheap and you can get them everywhere. Cheap fun if you get a clean one, looked after.
There is nothing cheap about dmf! Even the clutch is still expensive.. I'd expect to pay 250 for a full performance clutch only one I've seen is the black diamond that includes everything apart from flywheel
Go for a smf, fit and forget and most likely never have to replace again, shop about, cheaper than dmf. Just get it balanced before you fit it.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/261300552019 standard smf kit
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/261300450667 not standard smf kit
ive seen standard engines with K04s break the 300bhp and be around 300bhp. Need your usual decat and intake and a well kept engine but seen plenty do around 300bhp
