AdvenceeD
7
Hi guys,
Can you tell me what should i do to active comming & leaving home function in Ibiza 6j (2008 - xenon)? I tried do it by coding in vcds but nothing happend.
You need to have the automatic headlights as you need the light sensor for coming home lights to work
Reactions: AdvenceeD
Of you dont have lightsensor leaving home dont work. Coming home can work but jou need to flare one time with high beam to activate it. Also check of there is an option for activation of coming home with ignition switch or drivers door. Code this to drivers door. Also check in adaption settings what time the settings are. Somethimes its on 0 seconds. Then it also dont work.
http://seat-ibiza.sgpetch.co.uk/pag...terior/accessory=Automatic+Headlights/id=6645 here's a link. It seems to only be for the facelift 5 door 6Js though
unfortunally i've got prefacelift version so it will not work.
I tried today turn this on by flash beam with ignition off and doors open and still nothing happend, i also checked adaptation settings and the coming home value was set 15s.
I think i will buy this auto headlight switch from alliexpres, but i need to make sure it will work in my ibiza
Thats weird it dont work. Tried this? Normal it work..
Yeah i did exactly the same, maybe it doesnt work because ive got bixenon lamps, idk...
I tried the exact same when I got my car and it didn't work for me either. I'll give it another go tomorrow. I have the dual halogen type headlamps but mines a facelift.
I thought Bi-xenons could only be speced with FRs that came with auto lights/rain sensing wipers and tiredness recongnition? Could be just a 2016 thing, as mine is...
