Headlight removal
Granty312
73
Hi,
Got some side lights and they fell into the actual headlight component of the car (I now have 3 bulbs in the headlight itself )
What is the easiest way around this? Is taking the headlight component out simple or is it a fair bit of work eg removing bumper aswell? Is there a better way to get them out as I currently have one side light on driver side and none of the passenger side! Any advice welcome
Thank you!
P.s I have a Seat Leon 55 plate 1p TFSI!
Granty312
73
Jimbobcook
6,150
2,533
This sounds like a good idea, however I’m not sure whether the bulb would come back through the same hole if you get me as it’s a small fit? Would be a good idea though!
The metal plate should be on the bottom of the bulb so you should be dragging it thin end first which should help.
Better than removing the entire front of the car I think haha
Does the main beam share the same case as the side light as you could take that out for a bigger hole?
Granty312
73
Hopefully this will work! Yes they are in the same case if I’m right in thinking the bulbs are actually says in front of them main beam light currently !
Jimbobcook
6,150
2,533
Good luck lol I think the forum needs an action shot of you trying to grab it lol
Legojon
I only wanted a remap
5,284
2,714
And throw one of these into the headlight as well... just to mix it up!
latest
Granty312
73
finally got them in!! Used a tool that grabs! Thank you!!
