Engine rough, noise and black smoke exhaust
Alberfb88
12
Hey guys. So a few weeks ago coming on the motorway everything was ok. Then I stopped at a red light and car started sounding like a tractor in the engine area.
Havent used it since then. Today I went to start it to try and find out what it is and after the car warmed up black smoke would come out of the exhaust, idle is a bit rough as well. Any thoughts?
Leon cupra r mk1 with custom made exhaust is the car. Thanks buddys
BadBoy03
A Mk1 Is For Life, Not Just For Fun
Sep 6, 2016
778
582
Somerset
Not sure about the black smoke, any lights on? When a coil pack died on me, it sounded like a tractor & ecp was flashing. I would get it scanned as this would tell you the fault. I'm sure someone here can be more helpful than me.
Reactions: Alberfb88
Alberfb88
12
Thanks for the reply mate. I was told that by yhe sound could be the manifold. No lights on
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Black smoke could be running very rich , so it could be down a cylinder , but if no lights on it needs to be scanned. Could be a cracked exhaust manifold does happen and would appear to not be uncommon, could also be your custom exhaust has a blow in it somewhere.
mty12345
4,114
680
bristol
Sounds like the manifold. There's a fair bit of room down there, so when it's cold, try getting a mirror or your phone camera down there and see if you can see a crack.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
Coil packs can fail and not throw codes strait away but you will feel and hear the misfire.
Sounds more like a lumpy NASCAR that’s had exhaust pulled off. Also may have more than one fail at once.
You really need it scanned for faults though if you can’t tell it’s dropped a pack.
AA RAC if you don’t have a code reader.
Sent from my iPhone using Tapatalk Pro
