I noticed the same on ours, but starting to creep up now. Should get around 30mpg if you haven’t got a lead foot
Some things which should be very important to note is what gearbox you guys have, 6speed DSG/ 7speed DSG or the manual.
The 7-speed DSG should be the most efficient one, especially if you are doing alot of highway/larger roads.
I previously had a Cupra 290 with the 6-speed DSG and that revved quite alot in highways and caused high fuel consumption due to the rpm..
150 miles into my 300mile drive.. sat on the motorway at 70 the whole way and averaging 34.8mpg so far, engine obviously needs bedding in
Reactions: xyz
Somehow the words "economy" and "Cupra" don't combine in my head ;)
...with that said, my 4drive is a bit more thirsty than what I anticipated, specially when compared to the cousin Octavia VRS it replaced.
On a road trip through Norway, with long stints without traffic and low speed limits, it did quite well... But around town it is a disgrace ;)
You won't get much better than that. Mine is on 15k miles and sees those figures.
Reactions: kiddo
Cupra mode won't make you use anymore fuel tbh due to it not giving you anymore power only better throttle response
Of course it will use more fuel, when it's on the throttle responce is sharpened so it accelerates harder. The gearbox over revs and holds gears which drinks more fuel.
Totally off topic, but what's the reference to "Copra" in the title? Am I missing something? :p
Do you have a 300 4wd with 7dsg?
Some friends has the new golf gti with 7speed dsg and they have no issues with exceeding 40mpg.
So I would be surprised if it is impossible to achieve 40mpg with the 7-speed and 4wd..
This is probably my best so far ... and most boring :)
most of the time it's in the low 30s, when driving in London, short trips, 20-28 mpg
I agree. Got 11K miles on my Cupra and averaged about 35mog disincentive I got it.
I have seen as high as 38 when driving 100% in Granny mode and as low as 14mpg when in Heavy Foot mode.
To be honest no-one buys a Cupra and expects to get mid 40’s upwards. It just isn’t going to be able to sustain. And if you actually do, then the car isn’t being used to it’s potential, so in that case what’s the point if having a Cupra.
I went into ownership knowing my fuel bill was going to rise and to me the enjoyment I get far outward the extra cost.
You only live once. Enjoy it while you can
Reactions: Hickery1995
Im interested in mpg purely to compare to my current car, which is a m140.
It can do low 40s on longer trips and if a Cupra can only do 30-35 on longer journeys there is no way im replacing the bimmer with one..
I had a 6-speed dsg Cupra but didn't like the high Revs in the motorway, but if they even managed to get same or even worse fuel economy on the 300 with 7-speed dsg, then it's not interesting..
I have seen on here Cupra’s DSG 6 spd and DSG 7spd getting 40mpg on long runs so it is possible. I guess it all comes down to driving style.
If anyone wants to reach or get 40mpg regularly they should have bought a 2.0tdi 184. A 2.0t around 300bhp is not set up for big mpg, on the new 290's the 7 speed makes a difference on motorway journeys, If I'm sensible on my motorway commute I've seen 38mpg average. I prefer to have a bit of fun though.
Well if you consider a BMW m140 xdrive to be equal to a 2.0 tdi, that's on you.
I got it down to about 40-42mpg on a long run with some fun along the way but mostly on cruise at 120-130.
