Painting rear number plate plastic - advise
jkane92
51
Hello,
I've seen a lot of people have the plastic behind the rear number plate painted gloss black or colour coded to the body.
The people I've asked have used paint shops for it.
While I've got time off work I thinking of giving it ago.
Has anyone on here done theirs before and have any advice/ step by step?
Thank you
ray
590
190
I done mine on my mk2, the plastic is very slightly grainy, so needs to be sanded to a flat finish, other than that prime and paint as normal. :)
Reactions: kiddo
MGH74
47
Hello,
Thank you
I have a spare, new piece of plastic I’m about to put up for sale. Bought it to do the same thing as you, but never found the time and now the car is going if you’re interested?
jkane92
51
I'm okay atm thank you. If it goes horribly wrong you might be recieving a message.
Jaco2k
AWD FTW
Mar 11, 2018
1,037
635
Tampere, Finland
www.youtube.com
Can you make some photos of the back of the part?
I am also thinking about doing the same and it would be cool to find out how to remove it to paint it out of the car.
Reactions: S4BiT
S4BiT
163
115
And share the part number also, if it is from the facelift ST?! I have some plan also to colour-code it or paint to gloss black.
jkane92
51
Did you use any specific primer and paint? It's just because the plastic is quite flexible, don't want the paint cracking
ray
590
190
Just normal paint and primer, all you need to be wary of is the primer sticking to the plastic which will only happen if you’ve sanded it properly.
S4BiT
163
115
I know that there are special primer for the plastics on market, so best to use this.
ray
590
190
This was mine, no flakes or cracks in the two years since it was done.
Reactions: jkane92
jkane92
51
Okay I'll give it a go. When sanding down you want to get rid of the plastic texture but use a low grade of sand paper to leave the plastic rough so the primer adheres properly right?
Dannnnn
440
200
Hampshire
I assume you mean the insert?
I'd be interested if it's cheap.
I want to paint mine but would rather paint a spare then the one on the actual car.
Sent from my Pixel 2 XL using Tapatalk
MGH74
47
Yep the insert. I also have a new diffuser as well, bought both to paint gloss back, then fit and sell my originals.
Looking for £55 each.
MGH74
47
I’ll get some photos but if you look here, these are the parts. The insert fits all models, the diffuser fits SC and 5 door. Part numbers are on there, these are the ones I bought, just never used.
https://forums.seatcupra.net/index....a-sc-5-door-rear-bumper-insert-pre-fl.444830/
https://forums.seatcupra.net/index.php?threads/mk3-leon-cupra-sc-5-door-rear-diffuser.444831/
Reactions: Jaco2k
Jaco2k
AWD FTW
Mar 11, 2018
1,037
635
Tampere, Finland
www.youtube.com
Thanks - no need :) The links you just posted kinda answer all my questions :)
...just to confirm, these are facelift parts, correct?
MGH74
47
Pre face lift it said on the original post, although to be honest I can’t see any difference on the face lift version, but that can be confirmed with the part numbers.
S4BiT
163
115
Facelift and prefacelift have some design differences in this place if you are searching for the pictures from rear side of the cars.
Sochaux
82
28
Sorry to bump a old thread but I’m looking to paint mine, does anyone know how easy/difficult it is to remove the insert?
