connorman73 Active Member Feb 8, 2019 22 9 Feb 18, 2019 #1 I have the Mib2 with the screen in the image, is it possible to play DVD's on the system at all? Attachments s-l300.jpg 19.1 KB · Views: 146
paddy6789 Active Member Aug 31, 2016 1,479 927 Preston, Lancs Feb 18, 2019 #2 I've got mine playing dvds - have to enable it through OBDeleven or VCDS. Very easy to do
connorman73 Active Member Feb 8, 2019 22 9 Feb 18, 2019 #3 paddy6789 said: I've got mine playing dvds - have to enable it through OBDeleven or VCDS. Very easy to do Click to expand... Ah ok, I have the carista app but don't think you can do it in that.
paddy6789 Active Member Aug 31, 2016 1,479 927 Preston, Lancs Feb 18, 2019 #4 connorman73 said: Ah ok, I have the carista app but don't think you can do it in that. Click to expand... I don't think you can - maybe someone in your area with VCDS or OBDeleven can help you out
paddy6789 Active Member Aug 31, 2016 1,479 927 Preston, Lancs Feb 18, 2019 #6 superdon said: How's it done with obdeleven? Click to expand... There's an app on OBDeleven that enables it for 100 credits. Not sure what the underlying settings are.
Walone Active Member Feb 10, 2016 1,745 522 Near Heathrow Feb 18, 2019 #7 connorman73 said: I have the Mib2 with the screen in the image, is it possible to play DVD's on the system at all? Click to expand... You have to have MIB2 High unit with built in DVD player to play DVD's and it only plays them whilst stationary unless coded with VCDS/OBDeleven. Reactions: paddy6789
paddy6789 Active Member Aug 31, 2016 1,479 927 Preston, Lancs Feb 19, 2019 #8 Ah the obdeleven tweak is to enable playback whilst driving... Because you need to be able to watch dvds whilst driving for some reason.
