Hello,
Does anyone else find the power delivery on the 290 bloody awful? I've only had the car 4 months from new and it's starting to annoy me.
In Cupra mode if the gearbox is in standard mode it's laggy and doesn't pickup well in low gears, even in high gears it's as if there is massive turbo lag.
When in "sport" mode on the gearbox with cupra mode. The gearbox is snatching gears far too quick - so if you mash the throttle you get thrown into the seat however when you let off the throttle you get thrown back into the windscreen because it's as if the car is engine braking far too harshly.
I've tried all the settings and I can't see to get a decent level of response... and even a Mini Cooper SD seems quicker and nicer to drive!
Any thoughts?
Any thoughts?
Only reason I can think off with the raised idle is to have the engine closer to the powerband.
