What will happen to the conputers in the car if i change all my suspension to bilstein b16 coilovers?
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Thank you, do you know where I can get a DCC delete kit?If it’s DCC you’ll need a DCC delete kit so the car doenst flag up errors.
If to have LeD’s you’ll also need to have the level sensor reset. Seat cheap out with only one sensor at the rear, so even the front is lowered to, it’ll dip the lights as if your boot has an elephant sat in it.
Other that that I believe you are good to go.
The suppliers of the suspension can usually provide it. Not sure if bilstein make one, but KW certainly do. Doesn’t need to match the suspension make.Thank you, do you know where I can get a DCC delete kit?
Does that mean I will lose the ability to change anything from comfort to sport? (Like will it still work when I press the button in the car for the steering or engine or diff)That personal opinion really but I think it is yes.
You'd lose the ability to switch between comfort, normal and sport with DCC.
Damian @ DPM Performance
I've had my car remapped and it works in cupra mode, does this mean I will lose my remap because I won't be able to change the driving profile?Correct, you'll basically lose the DCC feature.
So what setting will everything be on when I do the delete? Like the steering, diff, engineYou'd need to speak to the company who did the remap to check that.
Where do they do suspension that plugs straight in?All the DCC delete does is trick the car into thinking the DCC is still connected, simply to stop error messages coming up on the car to say your suspension isn’t working. All the other features of the driver profile remain unchanged.
Personally wouldn’t want to lose the DCC and will be saving up for the more expensive bilstein/KW setup that plugs into the DCC still
Purely as I want it to still be comfortable.
Yes.Where do they do suspension that plugs straight in?
So if it plugs straight in I will be able to keep all my DCC functions?
But you said in an earlier post that I will lose all the DCC functions like the steering, engine and diff, but now your saying that I will only lose suspension features not all of the DCC. I'm very confusedMorning,
As mentioned, the only features you lose are to do with the dampers, everything else remains the same.
