Got round to fitting the Heko wind deflectors to the STFR
How'd it go? I'm paranoid about mine because the instructions say to use alcohol to clean the windows and it uses metal tabs to hold it in.
Fit no problem, not need to clean the glass as it doesn’t affect the fitting or use. Only thing I’m not 100% about is they only use 1 clip on the rear window deflectors.
I've got the SC so not a problem for me ;) if you say it's quick and easy I'll give it a go when I get home from work!
This.... I ended removing mine today. The drivers side never fitted properly and kept dropping. Maybe with more clips it would stay in better?
I think you can order more clips online. Which ones did you order? my heko ones have 2 clips rear and 3 clips front
Ok, it was yesterday but finished coating my wheels. 2 coats with TAC UHS ceramic, and topped with Quartz MAX
With the hot weather thought it best to stick my summer wheels on forgot how amazing PS4s are!
And a cheeky little photo from the Lake District.
I love those Alloys, don’t see many around
Reactions: Deano j1971
I would get extra clips and insert it where the panel is a bit loose, it’ll do the trick, I’ve done the same and it’s tight & wont have issues with the window closing as well.
Just installed my heko wind deflectors and AliExpress puddle lights on my 2014 SC
Deflectors still seem a bit loose, 2 clips isn't enough, and I'm not entirely sure they're in the right place. Kind of bent inwards a little bit.
Also had an issue with one window not closing and bouncing back down. I got it to go up by holding the deflector outwards from the outside, just hope after the adhesive sets it'll stay that way.
However I did fit these beauties....
straight from AliExpress, didn’t come damaged which is a bonus and fit perfectly.
Hi, please will these metal covers scratch the paint of the car? How close are they to the paint? I am considering ordering 4 pieces, but if they touching the paint, I won't want them. Thank you.
Do you think there is any chance anyone would use them if they scratched the paint?
There is for sure someone who put them on and did not care...
I would like to have it confirmed for real and not just thoughts
And lot of goods from China are sh*t.
Don't see how they can scratch the paint, you'd have to be proper ham-fisted to scratch anything putting them on, you just peel off the backing tape, slot them over and press in place, once they are on they are on.
Mine haven't scratched the paint, moved or come off.
New wheelbolts arrived. 20grams heavier than a factory bolt. But these are in high quality Steel :) And are black (why I bought them)
