Nice one!just under 3,000 miles and cupra mode. yea you can hear the farts from inside really audible.
Guess I need to get some more miles on my car!
you sure it isnt the soundaktorFrom delivery my car has been loud, odd?!![]()
you sure it isnt the soundaktor![]()
I did think that, but when the guy pulled up yesterday it was growling..
And yesterday i turned it off...
I have noticed though, from fiddling with the car, when you start the car and sit there door open, after a minute or so the tone changes, almost like a valve in the exhaust??
Did a few blips up and down a dual carriage way, without redline etc and every now and then it cracked if i lifted off at say 4k?
Thanks I’ll get one
Seen the vagparts one and a zaustwerks one for a lot less
Can’t see there being much difference in them?
Hi the VAGsport kit we supply is almost unanimously referred to as the best on the market. VAGsport have gone to great effort to research and development with regards to producing the best kit on the market for enthusiasts, there were several development kits designed and tested to minimize the unwanted noise associated with a resonator delete kit. From there members of owners, clubs were invited down to test the kits and choose which one they liked the best, so the kits are quite literally the enthusiast's choice.
Main benefits of the VAGsport kit :
- 70mm pipe construction, not 65mm then fairing out at the end.
- Mandrel bent so no restrictions on the bends
- Single piece construction not 3-4 pieces welded together
- CNC mandrel bends for a precision fit
- Fully reversible with the clamp kit provided
As for the discount yes we have a code I can supply once you're ready to order
- The reason we supply 4 different kits for the Cupra's is simply the different configurations we've seen over the years in these vehicles.
Hi, Thank for the question. We haven't seen a 300 4drive with WLTP but if you can send us some pictures of under the vehicle I will be able to tell you for sure.Version 3 is for the Cupra 290 WLTP 2019?
What about Cupra 300 4Drive WLTP 2019, do you have something for it?
I’ve also noticed this, i’m sure its due to it idling at a slightly higher rpm as soon as you start it and then idling at a slightly lower rpm after a short while.
That was my 2019 ST which I took to VAG Progressive Parts in Manchester & they photographed... I presume there is no solution to this yet to give the car more noise?I cannot attach images, but you can see how it looks in this thread (first post):
https://forums.seatcupra.net/index....pra-st-4-drive-resonator-delete-issue.448585/
There are 2 small GPFs (compared to only one, but bigger for the Cupra 290 hatch) and no resonator.
I’d like to but too embarrassing to drive around with a camera stuck on the back lolAnyone got and gopro videos of a red delete yet?
I won’t tell anyone if you don’tI’d like to but too embarrassing to drive around with a camera stuck on the back lol
Maybe just me
