Did the foglights to LED - made a
video also, that will come later.
There is good and there is bad:
- lights are now way brighter
- did not need to code anything
- I had turned cornering lights on and now they do light the corner part
Bad things:
- even though I purposely chose a 'safe' style of LED bulb, they glare like crazy and the pattern is all-over the place. You can't really use them as foglights anymore and even as cornering lights I have some doubts.
- the bulb construction has a fan at the back, which is exposed and in general, weather proofing doesn't seem the best, so I assume that when they get wet, they are going to fail.
In general it is a good and easy mod, but it needs the suitable bulb type.
Probably just splash extra on the Philips Ultinon LED H8 bulbs.
