Zayynn12
49
I’ve done some coding on my rear lights ( see below) but I can’t figure out how to reset them back to standard or at least switch off the right rear light (3 dots) from flashing when I put the left indicator on (video)
Attached the coding I did to get to this stage too
Did you use vcds? Then there always is an log of adaption settings you change.
What settings did you use? Leon 5f?
Ibiza 6F has other "light(leuchtes) functions" zo they dont work on a ibiza 6F..
Verstuurd vanaf mijn SM-G965F met Tapatalk
I used obdeleven on the new mk6 Ibiza they do work it’s just when I put the left indicator on the 3 dots on the right light also flash.i just want to stop the flashing of the 3 dots
I know what you mean.. just look at the "leuchtes" and check if one of them is not correct coded. One of this has to be blinken rechts dunkel or helphase on the lichtfunction. (A,B,C,D,E,G,F or G)
No other A B C D E F looks out of place
Is there a way I can show you what settings are on my car so send you a log somehow?
I’ve taken pictures of everything that was changed, do you have an idea now how to switch them 3 dots off
(Screenshots are over two posts)
3F4B8293-CF7A-4D22-B7F8-195713F4FB59.jpeg 18D7F3D9-6817-4707-A8FC-F0345369F7EE.jpeg 03F2FE5E-AAF9-4F68-9177-DCCC80F6B050.jpeg 6DCC02DD-819C-428B-92CA-0F26CB26BD4E.jpeg 330E0E10-D701-4F11-A962-D0D8B901596B.jpeg A1C372BA-8C8A-4E94-989B-49036FD94A49.jpeg C2585CC4-6E0F-43A6-A194-C6DF7CB364EE.jpeg 8800333F-75A7-4DF2-97B4-9F7ABC75E82F.jpeg ACE0BC4C-918D-4443-AB43-FE29543F22DF.jpeg 7ACB066D-FE80-4061-AE4B-A1C509B11C5A.jpeg
Check your settings in leuchte 24 and 27. This is die the right unit.
Also the lepn 5F has 23,24,26 and 27. Leuchte 23 and 26 is left unit. 23 outside and 26 inside unit.
For right unit 24 is outside and 27 is inside unit.
The ibiza 5F dont have this.. trie to set leuchte 27 blinken rechts to not Active. And then leuchte 26 etc. Til the light is off.
Thank you, you’ve been a great help I managed to get it turned off by switching off G and F value to nich aktiv for both Leuchte26 & 27 and then it worked
I left everything else the same I.e dimming, dimming direction
That should be okay I imagine?
Reactions: at0ny
No thanks! I code this options a lot to vw, audi, seat and skoda..
Yes that is no problem. You also could set dimwert to 0% if you put this to 100%(output)
But with not Active this is the same. Only for some functions. You need dimwert. Like with us lights etc.
Problem with coding leuchtes not all the cars are the same... ibiza 6F have other leuchtes, then a leon 5F etc. I always check them before coding.
Aah okay I see, thanks for the tip
I just saw it on YouTube and thought they looked better than the standard boring ones
do you have Any more coding tips or tricks ;)
Can’t seem to find a lot to code on the facelift models
Also one more question, I also use Carista to code and whenever I try “needle gauge on with headlights off” it keeps rejecting the coding, any suggestions on how to have gauges lit even with headlights off
I dont know how Carista Works. I only use vcds or vcp die coding etc.
I never had problems with needle sweep. Only on virtual cockpit of dont work. Done a lot needle sweep activation on the ibiza 6F with no problems. Also with drl on, headlights on or off.
My needle sweep works fine it’s just that if headlights are off they won’t stay lit I can’t figure out why
They're not supposed to stay lit, there's a sensor. If it's too dark outside, the backlighting turns itself off to remind you to turn on the lights.
Aah ok that makes sense thanks
It stops the issues often seen on Fords and PSA Group cars- morons driving around with no lights on because they have bright DRLs on the front and an interior lit up like a christmas tree! The DRLs are all well and good on the front, but of no use at the rear of the vehicle!
True true
Unless you have them enabled with DRLs just like me ;)
