Maybe get the genuine Seat Aerodynamic "Sports Styling" kit if you want discreet, should help at resale v aftermarket kits.
Not cheap mind, you can get genuine parts from sgpetch or seataccessoriesplus, but the dealer at lookers manchester pretty much matched online.
They come primed so would need painting and fitting by bodyshop/seat.
Parts £1,000, Painting and fitting £650.
I'm sure it can be done cheaper but I wanted it done properly and happy with it. There are some polish shops on ebay doing replicas much cheaper, not bumper though.
I got the rear bumper done too and think this made the biggest difference to the look. Squares it off and gets rid of the large space of plastic around the reg plate.
Hope this helps in someway!
of course other options available![]()
Original
Good find, make sure to check which black you have though as mine is phantom black not midnight. It might be slightly different?These genuine SEAT side skirts are already painted midnight black from the factory for £225 which is a bargain. That's if your Leon's a 3-door! There's usually lots of pre-painted genuine SEAT roof spoilers and side skirts on Ebay, but this is the only one at the moment. Worth keeping an eye out, as it would save you a fortune on painting.
https://www.ebay.co.uk/itm/GENUINE-...510357&hash=item1ef876532c:g:L38AAOSwxlxcXIGY
Yeah does make a big difference. I’m far too tight to spend that sort of money. Will have to go aftermarket I think. Yours looks great
You can choose, i didnt bother with the twin exhaust as it was another £500, happy with original.I thought the original Seat Sport Styling rear bumper came with twin split exhaust with 1 exhaust tip on either side?
Got them off ebay, they have VW oem markings on them but easy to copy i suppose, £22, but they look the same@Jamesb are they the ebay/aliexpress jobby or genuine VW from a GTI/GTD?
Sports pedals added![]()
Have you got a link? And do they go on top of the stock rubber or do you have to peel/take off the stock ones?Got them off ebay, they have VW oem markings on them but easy to copy i suppose, £22, but they look the same
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/113763122175Have you got a link? And do they go on top of the stock rubber or do you have to peel/take off the stock ones?
I want the rear spoiler too. Can't believe they do all the other things as standard on the FR, then give it a shitty bog standard spoiler.
