Is the new engine reliable?? I read lot of issues of" kangaroo effect" and now I am afraid of buying a new car. Should I worry or not????
.I have the 130 1.5tsi evo engine with manual box
Kangarooing is only in 1st gear on a stone cold engine so first pull away of the day its a bit jerky but other than that its acceptable
Never owned the 1.4 tsi so obviously cant compare to that but its the new engine it has to be better surely plus its going in absolutely everything across the VAG range
I also have a 1.5 evo (130) in fr guise.
Previously I owned the 1.4 evo (150) tech model - that was a cracking car, had it for 4 years and it never needed anything apart from routine services and replacement tyres (37k over 4 years) the 1.4 (150) is responsive and efficient, as happy to dawdle in 3rd all day as it is to be thrashed within an inch of its life!! If it had been an option I’d have rolled into the same spec car.
Having bottled it with 2 weeks to go on a factory build Arona fr 1.6tdi I was able to switch for a ready built Leon fr (130) think this would be similar enough that i wouldn’t notice the difference....
But the 1.5 is a different beast, although the 130 & 150 essentially share the same engine the turbo set up is very different.
I can’t vouch for the 1.5 150 as I haven’t driven one, but I find the 130 underwhelming, not sure how they managed it but the 130 has just 200Nm torque, the same as the 1.0 3cylinder 115 bhp used in an Ibiza or Arona and these are both lighter!! Somehow the VW Tiguan has an extra 22Nm outta the same 1.5 130
There is power there but it’s not instant as per the 1.4 150 - you have to plan things as bit more and the the turbo takes a bit longer to build up momentum, I also find it noisy when pushed.
As for the kangaroo effect - yeap I have that too, usually the first drive of the day, or when it’s been sat around for a few hours, I found it is more prominent in sport mode so I keep it in normal most of the time, I’m keeping an eye on the t roc/briskoda forums for the confirmation of the fix as so far my dealer has denied the issues or blamed it on my driving style.
Any particular reason? I use Eco just me (most of the time) and Normal when friends in the car.Eco mode is dangerous
Just the lag between hitting the go pedal and it actually moving especially when coming out of junctions or trying to overtakeAny particular reason? I use Eco just me (most of the time) and Normal when friends in the car.
Not quite sure I understand this...although I've never compared journey MPG against Eco or Normal Modes, both Driving Modes offer a 'normal' mpg when driving then an increased MPG when ACT is active and if on overrun via gear engine braking or going down hill with foot off accelerator engine fuel shuts off completely. You can see the reading and effects using Instant Consumption selection.Out of interest why go back to normal mode when you have friends in the car if you normally use Eco mode?
For me Eco mode uses around 3-4 mpg more fuel over a 150 mile A road journey as it uses fuel when going down hill to keep the engine running whereas in normal mode no fuel is needed to keep it running..
