Quick Shift
MrJohn91
136
64
www.facebook.com
Has anyone fitted one of these? One thing I find frustrating is the travel time on the gear lever and this would help massively but wondered what peoples opinions were?
https://www.forgemotorsport.co.uk/A...d_Adjustable_Quick_Shifter--product--989.html
also this one is significantly more expensive... is this just because the Forge one only changes up and down travel and the APR will amend both up/down left/right?
https://www.regalautosport.com/shop/pr-adjustable-short-shifter-full-system.html
LR231998
Alor Blue 290 Cupra
Jan 21, 2019
485
188
Most just do the vertical short shift and from what I’ve read it is a great little mod. However I’ve also read that the half price on eBay short shift kits are just as good as the “branded” expensive ones. I’m interested also in the future .
MrJohn91
136
64
www.facebook.com
That is interesting to note. I may gone down that route then instead and add this in for the same money as the branded short shifter alone. https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/264277553231
Sent from my CLT-L09 using Tapatalk
AndrewJB
Aug 16, 2007
11,175
485
Maranello
on my MK2's I had the forge kits for front-back and left-right. The front back is brilliant ( I also had fitted to a MK2 Golf and now MK1 Leon).
The left right kit is "good" but you wont notice it as much.
Reactions: MrJohn91
Jordan Neill
91
17
Did you get this fitted, what was it like as I'm also looking into getting a quick shifter.
Watching thread TIA.
Kibby
450
39
Belfast
Not done yet but will be doing soon. Will update when done
It has been some time, not sure if you still own the car, but did you ever get round to fitting this? And if you did 1) how difficult was it and 2) what one did you buy 3) was it worth it
Jordan Neill
91
17
I can answer, I bought mine. I've got it set to its shortest throw and makes a massive difference. Can make selecting first a little weird at first but otherwise a great purchase.
paddy6789
1,627
1,082
Preston, Lancs
Not meaning to throw a spanner in the works, but I ordered a different kit all together - I got the Diesel Geek Stigma quick shifter set, which I think is fantastic. @Charliessmith has a set too. Not the cheapest but the look and perform great.
Charliessmith
494
51
I must say I'm extremely happy with the Diesel Geeks short shifter kit, it feels amazing and really shortens the shift quiet a bit.
@paddy6789 told me about it and he got it first and from what he told me about how it feels and performs I had to get it, and I've never thought twice since.
It also looks amazing.
Sent from my SM-N770F using Tapatalk
MatTheMerciless
84
55
I’ve got the forge short shifter installed. One of the best mods to date. Makes it far easier to drive.
With the stock gear linkage bushing the car was almost undriveable though. Worth putting aluminium ones in while you’re there. Took probably 30 minutes to install. There’s a bit more noise through the gear stick with the aluminium bushings but it’s only noticeable at low speed.
I also found the shortest setting was stupidly short. Stock throw was 7cm from neutral to gear. It’s now 2cm.
Leeon
29
10
Hey I was looking to buy 1 of the short shifters from eBay opposed to Forge, however I am interesting in replacing the bushings as well, how many would I need to order from Darkside devs as £30 a pop is quite pricey. cheers
MatTheMerciless
84
55
I think the Forge one is CNCed from billet aluminium, hence the price. eBay one might be cast so be careful and buy from someone reputable. You only need the one kit from darkside, it’ll have two solid bushings. Triple check which ones you need though as there are a few options. Pop your air box out and have a look or email darkside to ask. They were very helpful. From memory the round bushing was a pain to remove and fit. Give yourself plenty of time and make sure you’ve got tools to hand.
Reactions: Leeon
Leeon
29
10
Thanks for the Advice, I emailed Darkside and they say the model which apparently I have on my 2014 FR ST 184 is 5Q0711046K, there is no short shift replacement for this.
Mr Pig
2,916
1,089
The gear change on one of our Leons is notchy feeling, even after the car has warmed up. Any idea what can cause this?
It's a facelift car. The two pre-facelift cars have been smoother.
CalJames
Modification Addict
Jun 25, 2019
342
157
North Wales
Different gearbox based on engine possibly.
My 1.4 feels very notchy compared to the other half's 2.0tdi, the throw is also a bit shorter on the diesel
QTom
77
16
My Cupra is also a bit notchy, mainly when cold and mostly on 1>2. As far as I understand it's pretty common but would be nice if there was some way to improve it.
Reactions: Mr Pig
Mr Pig
2,916
1,089
Yes, that's what mine is like. The 1.6TDi and 1.4 TSi were fine but the 2.9TDi just feels like crap. Like there is a bit missing or something. Can't help but think maybe something is misaligned or something.
