Maypack
Apr 20, 2014
2,943
2,153
Gods Country - West Cumbria
During a drive up to Glasgow today I ran over some hedge cuttings which bounced around under my car.
On arrival at my hotel I was informed by MrsMsypack that there was a puddle of water under my car. I looked underneath and removed some wet debris and cleaned the area up and all looked well. After a walk and food I went back and checked under the car and it was dry. MrsMaypack suggested moving to another parking place (car next to me was too close ) so I did.
When parked up there was a dribble of water and a number of drips which has slowed down but not stopped.
I have checked all bottles under the bonnet and all are showing correct levels
The water is dripping from this area underneath but I have no idea where it’s coming from
I have tried the front and rear windscreen washers and both work fine with no extra drips when being run.
It is definitely water and I’m wondering if some wet plant debris is under my car or if I have a problem? Can’t get to a garage as I’m at a Foo Fighters concert then parking up for 10 days and flying to Malta.
Any Mechanically minded people any ideas?
Did you have the AC on? More than likely from the condensate
Reactions: Maypack
If the aircon has been on it could well just be condensation dripping from that, its really common.
I did have the Aircon on and the Engine was still hot too. If it is the Aircon should the condensate stop then if the car isn’t driven for a day or so?
I did have the Aircon on and it was a 2+ hour journey. Thanks for the info
Regardless of knowing this I still always panic when I see the puddle under the car... i dip my finger in it check its not coolant or something! lol
Did exactly the same and due to plant debris bashing around under the car I assumed it had caused damage. Hopefully that will not be the case
it can pool on the undertray and drip off... if its just condensate then it wont smell of anything really, but it will be greasy to the touch. If its coolant or washer fluid then it will have a scent (assuming you dont just use water).
No scent to it at all. Just looks clear like water but doesn’t appear to feel greasy at all.
I would doubt its anything more than condensation then... it only feels greasy sue to it dripping down the engine so it may just not get greasy. :)
Reactions: Maypack
Well, if it's not coolant and it's not oil... it's nothing the car needs. To make you feel better... here's a picture of @jimbobcooks car @trax. Be sure to look closely near both wheels.
Reactions: ray
Oh and if it was p!ssing down of rain on the way... it could just be rain water dripping off the subframe or from the sills. I get this for hours after a storm.
Reactions: Bedlam
Mine was more central and at the back of the engine though.
Yeah, that's where mine drips off too..even I panic sometimes because when I pull into my driveway, it leaves a puddle as I go up the lowered kerb, then a trail that follows the center of the car. I get some looks as I'm in the kerb sniffing my fingers.
Reactions: Maypack
My AC condensing liquid can be extortionate and last for a while when warm. Enough so I’ll get someone mention it at work, and at least twice now I’ve been on my knees dipping fingers in wet patches...
:clown:
Reactions: Maypack
That was me to a tee!! Got a few strange looks from others in the car park.
I panicked big time but totally forgot about AC.
