Temp sensor?
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
731
Leeds
The red flashing light on the temp gauge is flashing on start up and occasionally going to 100°c on idle. Is it the temp sensor that needs replacing?
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
Yeah CTS is the quickest, easiest and most obvious thing to replace here.
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
There's one coolant temp sensor and it's located on the right hand side of the cylinder head above the gearbox.
Very simple to remove, just a plastic horseshoe clip holding it into the housing.
Remove the wiring plug first
have the replacement one nearby ready
Pull the clip out
Quickly pull the old CTS out making sure to bring the o-ring out with it.
Fit new one quickly so as to not piss all of your coolant out onto the street.
Slot clip back in and plug back on.
Top up coolant if needed and drive.
Reactions: bigT's lcr
