New steering wheel all fitted/ coded and working. Only took around 10 mins to do.
Hmmmm has anyone done this?
Hi yes you need steering controller 1K0953549CH thats what i got, this is located under the steering wheel, you also need to change the canbus gateway unit to 7N0907530AF if not done already then code in with VCDS. you should be done then.I’ve got a Leon mk 2 pre facelift model, 2.0 petrol FSI.
I’ve upgraded all parts so it’s now a facelift FR replica. Only thing I haven’t changed is the steering wheel...
I’ve recently purchased a facelift steering wheel, installed initially and connected all cables in correctly, however I had no horn function or steering wheel controls. Can live with out the steering wheel controls for now but had to remove as need the horn
Does anyone know if I need to change the control module in order to get the horn working or is this just a case of coding? Moving from that, would the control module need to be changed for the controls?
Okay great, I’ll order the parts, fingers crossed it all works! Quick question, when you did yours, did the horn work when you changed the module over or did you have to code it for the horn to work as well?Hi yes you need steering controller 1K0953549CH thats what i got, this is located under the steering wheel, you also need to change the canbus gateway unit to 7N0907530AF if not done already then code in with VCDS. you should be done then.
