Esp light on after battery change
Dazzalcr
342
333
Lancashire
Hi all,
I'm new to this forum even though I've had my cupra r a few years now and have found some great advice in the past on the cars issues many thanks, these are a great car for there age.
Recently my car battery was dead as can be so I've swapped it over to a new one, and now the esp light is on and not by choice, I've been for a drive and the cars great not lumpy and drives as should, I have done the whole drive it forward and full lock left and right still no joy, also did a scan no engine codes but I did scan abs as well and got g419 pop up, did not have this before battery went dead do I need to clear it with vcds as my unit wont.
Yellow fr
Sep 6, 2018
1,519
1,053
Sandbeds West Yorkshire
Yeah clear it and try it it should not come back if there is not a fault get it sometimes with flat batteries
Dazzalcr
342
333
Lancashire
Yeah I'm going pop to garage in morning as he has a snap on machine but he cant clear it then there is someone with vcds, yeah it was fine before so dont suspect it to be a pro8cheers pal.
andycupra
status subject to change
doh, you clearly said ESP and not ABS, for some reason i thought about ABS...
unfortunately the yaw sensor, (i think that's the sensor affected) do fail.
mine went on my cupra a good few years ago, think i got it done for about £15 exchange.
but do try to reset it, you may be lucky..
Dazzalcr
342
333
Lancashire
Lol dont worry pal, yeah well went garage he could not clear it so bought Ebay part for as you said 15 notes slapped it on and it's gone thank God luckily not a big job to do as it was freezing swapping it over grrr.
Thanks all for advice.
