Sorry, I thought you meant floor mats! I think aldi occasionally do the trimmable rubber grip stuff tho....
https://www.amazon.co.uk/LFOTPP-Gate-Rubber-Interior-Accessories/dp/B07GDK5ZH4/
Anyone know where i can buy something like this for the Leon ST?
hunted high and low but cannae find anything :(
They’re standard on the FL Mk3 Cupra ST that I have, just black though. Didn’t have these on my Pre-FL FR hatch though.
https://seat.7zap.com/en/e/leon+leon+4/le/2016-754/8/863-863060/
Have a look at the part numbers listed for parts 22 - 26 via eBay/google etc. Note: Parts list doesn’t always reflect the diagram (for 2016 model).
or some info from overseas - have a look at the post with the photo, and the part numbers listed in the posts below it:
https://www.clubseatleon.net/viewtopic.php?f=1&t=106432&start=360
Sorry - failed to mention in my last post that the sizes of the cubbies etc may be slightly different between pre-FL and FL cars.
@gaza1994 if you decide to try OEM and need any measurements from my FL Hatch just let me know :).
I’m 300 miles away from my car this week - @HowGudAmI it might be worth looking at the OEM part numbers stamped on the back of each of the rubber inserts in your vehicle, to cross ref with the numbers given in my previous post.
I've been looking for these for ages. My PRE-FL center console looks different to those pictured which is annoying. Anybody purchased these for a PRE-FL ?
Hi All,
I have just checked the part numbers on my Facelift Cupra Hatch.
Centre Console:
5F0.863.301.B - Two cup rubber mat (one circle bigger than other, all one piece)
5F0.864.175 - Large rectangle mat between cup holders and arm rest
5F2.863.328 - Small rectangle next to electronic handbrake
Under Arm Rest:
5F0.863.328 - Long thin rectangle
5F0.863.328 A - Large rectangle base
5F0.863.328 B - Small rectangle
Large rubber mat under AC controls / Screen etc - No part number.
As a side note - I think these are well worth having if you don't currently have them - they really dampen any rattle from coins etc.
My interior is this kind of design (using a press photo):
Reactions: Sword
Hi All,
Centre Console:
Under Arm Rest:
hmm, sadly my centre console is quite different from that image!
tbh its mostly the door "pockets" im bothered about, i accelerate and my vape goes flyin back haha
Me too, only i don't have a vape. I'm reluctant to buy the set just for the door mats.
Unfortunately there is nothing in the door bins of my car - so guessing there's not an OEM part for that unless your door bin design is the same as a higher end VAG car - VW, Audi...
Probably the easiest solution would be to pad it out yourself with something. As it won't really be visible you could just get the closest appropriate size of something like this: https://www.amazon.co.uk/dp/B01LW9P1GC/
For some reason i only have 2
big one at the front of the centre console and the one beside the electronic handbrake, must of got pinched before delivery
I made my own from old rubber mats from my last car. Made them in paper first to get fit right, then traced around with wide blue felt tipped pen and cut them out, simples.
Reactions: Tivver500
