Pcv breathe pipes
Madda
26
Wakefield
Hi all I have a 1.48valve mk2 facelift 2002 . Has anyone got part numbers for pcv valve and the 2 pipes that come off it . On I think is a oil breather that goes under pvc valve and has a bend on it and other one goes to throttle body can’t find them anywhere thanks all
SEAT Rule
188
62
Hello there according to ETKA site these are the part numbers below, for engine code AUD 1.4 8v this engine was used from year 2000 to 2002/3 in Ibiza.
PCV (Positive Crankcase Valve)
Part number 030 103 765A
Breather hose for above valve
Part number 030 103 493CT
Part number 030 103 493DA
Purge solenoid valve
Part number 051 133 517
(this valve opens to recirculate fuel vapour fumes from fuel vapour canister)
Vacuum/breather hose (connects to above valve then to base of throttle body plate)
Part number 030 133 518H
Hope this helps
Si
SEAT Rule
188
62
Thanks seat rule now maybe I can get somewhere again thanks
No worries, if you enter the part numbers on Google or Ebay it'll show you the items in question their size and shape, so you can double check what's fitted on your car currently before you remove anything.
Si
Reactions: Madda
