Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
I may be wrong but I think generic OBD codes start with a 0. If it starts with a 1 it's a manufacturer's specific code so you will need something like that mentioned above or VCDS. I'm not that sure about this, but I think I'm right.
Good luck - let us know how it all pans out won't you?
I'm going to get the multimeter out tomorrow to see what I can find out.
I'll also double check all connections, wiring, etc.
Surprised NTK is the default brand for VW. I thought these were the cheap(er) brand as opposed to Bosch.
As is so often the case! Especially with the exposed positioning of many post cat O2 sensors. Wiring faults and connector faults are common enough to be always worth checking first. In fact, if you find yourself immobilized out in the wilds somewhere, perhaps without even a multimeter, it's always worth just unplugging and then reconnecting any connectors that are easily accessible. Just occasionally you'll find yourself on the go again. I'm assuming you will be a person with some interest and knowledge of cars. If you don't even know how to overcome the locking clip on these plugs then probably you should just stay in the warm and call your breakdown provider.Turned out to be a dodgy wire!
Thanks for the responses folks.
Yes - easy fix this time! Glad I didn't go down the route of replacing MAF sensors (which was previously suggested).
Absolutely am but limited to what I can do without building a decent toolset, which will take time! I do wonder how long the "average mechanic at home" will last, given the complexity of new cars now and their computers....
