Wilkesy
255
29
Just wondering how to get scratches out of my window ?
pictures below is my passenger side but my driver side has a couple on too, shows worse when the sun is glaring through.
I’m off work next week, so Im going to have an attempt at getting them out. Theyre not deep just seem to be fine long scratches.
cheers
Cerium oxide glass polish and a glass polishing pad, and either a machine polisher or a strong arm as it takes some time by hand
Reactions: Tivver500
wiping the window with a ring on
mine is the same, literally takes nothing to scratch them
Mine too. Never had this on any other car; SEAT must have a special supply of extra soft glass .......
Cheers guys I don’t wear a ring either tbh.
Sorry for the crappy spelling and not making sense in the original post, I was in a rush for work...
going have a go with a pad before buying a tool
^ this
I have noticed the glass appears quite soft. My rear glass has some scratches on it already and I am extremely careful!
haha cheers for that
As above machine orbital polisher is best as glass is hard work but if it’s scratched that easy then perhaps won’t be that difficult by hand haha.
Just remember circular motions and depending how abrasive the first compound is you use you’ll probably want a smoother polishing compound after to clean it up or a light hand.
If you use a machine just be careful to make sure you move around the glass and don’t overheat it in one spot or you might not have any scratches to worry about (que a quick call to window replacement company haha).
Good luck.
Reactions: Wilkesy
I don’t think I’d attempt to polish out glass scratches by hand - IMO far too much like hard work, and the results might be disappointing (i.e. the chances are, the scratches will still be visible).
Probably not so much of an issue on side windows, but I’ve read on other forums that polishing scratches out on the windscreen can cause optical distortions if polishing for too long, or with too much pressure, or with too abrasive a compound in the affected area.
