Hello there and welcome to the Forum.
Normal operation is depressing the clutch pedal to floor, with clutch now disengaged you ideally should be able to obtain all forward gears, if you mean you have to lift your foot up slightly to allow clutch pedal to raise a bit, so you can then engage first gear, no this isn't normal.
Unless I'm misunderstanding what you're saying ?
Normally if you have to mess around like that to get first gear, it can be a sign that your first gear syncro is wearing.
Si
