Anyone know where the speed sensor is on a seat leon FR 1.9 tdi 2005?
Sent from my E5603 using Tapatalk
Much aprriciated. Thanks![]()
Is this the front i take it?![]()
Have a good day!Probably means your clutch is on its way out. Monitor and it will probably get worse over time so you should know when to change it. Mine has been doing it for months but hasnt got any worse yetSeat Leon 2009 Tdi 1.9 just got this car and I’ve noticed when iam taking off or in reverse there is an vibration or shudder when I release the clutch
All help welcome
Thanks mickee
Hi my air bag light has appeared and all of a sudden my battery is flat, is this a related problem ? I have read so much about softwear issues is this something I need to explorePossibly the connector under the passenger seat. A quick search will bring up previous threads I imagine.
You definitely do need to need to sort it ASAP. When the airbag light is on, all airbags are disabled in the vehicle.
One way to check that would be to graph MAF expected against MAF actual while you give it a good hard drive. Used to be the best way to find a duff MAF. https://www.ross-tech.com/vag-com/cars/tdi.htmlHi I’ve had a p0234 on my 2010 Leon 2.0 tdi sport and going into limp. Vacuum checked all pipework and corresponding components and all hold vacuum. Actuator arm moves turbo vanes. Only thing I noticed is when vdcs testing boost solenoid vacuum is 25” idle the same as the vacuum pump is creating but when not being tested I’m only getting 16.5” idle. Might be normal but I assume I should have 25” vacuum when the Solenoid valve is on. Could this be the ecu being sent wrong information by MAP or MAF sensor?
Thanks So obviously the expected should be close to actual. Was going to disconnect it and let the ecu go to default to see if problem went away then I’d know. Also think I should clean the map sensor. Only done 43000 which isn’t much. Been doing my head in lolOne way to check that would be to graph MAF expected against MAF actual while you give it a good hard drive. Used to be the best way to find a duff MAF. https://www.ross-tech.com/vag-com/cars/tdi.html
