CODING WITH ODIS
Please note: The procedure described below for encoding and enabling the trailer mode only serves for a general orientation and can vary greatly depending on the model (motorisation / equipment). If necessary less or further control units will have to be adapted.
Model year 2021 vehicles are equipped with a vehicle diagnosis protection (SFD). Make sure that access to locked on-board control units is granted by the diagnostic system:
Encoding 19 (Gateway)
- Control unit self diagnosis
- Access Authorisation
- Online SFD activation
- Execute
This enables 90 minutes where the adaptions/
coding can be performed before the module is 're-locked'
Encoding 09 (Central Electronics)
- Execute
After connecting to ODIS, the "69 trailer function" controller has to be set to encoded in the target installation list.
The following may be necessary in the further course of the work:
EZE_09 (Central Electronics):
Diagnosis
(possible login code: 31347)
Networking plan
Controller self-diagnosis
Encode
Trailer connection device >installed
or: hitch ecu >installed
Alternative encoding EZE_09 as follows (MY 2017 >>)
Self diagnose control unit
Access authorization >31347
Adjustment
Intergration
Trailer control unit > installed
ZKS_46 (Central module convenience system)
trailer monitoring >put on active
trailer control unit >installed
SWA_3C (Lane Change Assist)
ECU for draw bar >with ECU for draw bar
SW2_CF (Lane Change Assist2)
SCH_17 (Dash panel insert)
Trailer >yes
RFK 6C (reverse camera system)
equipment_ahk >installed
STF_74 (chassis control system)
Trailer >installed
EPH_76 (PDC controller)
Trailer >trailer device can be removed manually
DIS_13 (controller distance control
(possible login code: 20103)
Control module for towing sens >installed
Alternative encoding DIS_13 as follows:
Access authorization >20103
Encoding
Binary encoding
Byte 3
Binary > xxxx1xxx
or Hex > +8
FFF_A5 (front sensor system controller)
AAG >coded
HDE_6D (boot lid electronics controller)
Trailer >installed
Encoding 03 (Brake electronics)
Adaptions
Vehicle and trailer stabilization
Set to Active
Important note on encoding and activating in trailer mode:
The electrical system and saved locally. During general updates for aforementioned settings are carried out in the vehicle's the vehicle software (for example, within the scope of
service or repair work), the settings may be overwritten and deleted under certain circumstances. In this case, the trailer mode activation has to be updated again locally after the update. Diagnostic information relating to the trailer mode that may appear during variance comparisons with the data saved in the manufacturer's works, may form the basis of the local activation.
