I think it depends on the phone you have.
I have a Galaxy S9 and when connected using a cable, it is not charging using the wireless pad when I place it in the tray area.
Suspect if it's a wireless charging phone it's clever enough to know it's also getting a charge from the cable. I put my old HTC not wireless charging one on the pad with the USB cable, no issues. I use to worry about it being zapped .
Is that with the standard infotainment like Yanivkoval's ?. Not the high unit with Jukebox on the Media button ?. It might be the availability of the cartography that dictates what they put on these units although the Australian one had the mib2 standard as well. All the European sold Ateca Cupra's have the high unit.
Several simple tests. If you press the media button on the infotainment and it does not show the Jukebox as a media option with the SD slots it's a standard. With maps showing and no map card in the SD slots it's a high. The maps are stored on an SD card on a mib2 standard found in the SD slot. On inbuilt memory on a high, the spare memory is used as somewhere to play media from as well, called the Jukebox which you find on the Media button.
