Check oil level! Warning Light
gaza1994
49
15
31
Scottish Borders
garethjohnstone.co.uk
Just had this popup on the dash...
I checked the level after leaving the engine for 5 minutes and this is what i got
I let the engine cool for a couple hours and i seem to have more??
What should be the correct action to take here - im hopeless when it comes to this kinda stuff
(also worth noting, the warning has NOT popped back up since I checked the first time.
Yern
697
352
I had the warning come on (never before) during a sharp left hand turn from roundabout at about 25mph. Level was between Min and Max but obviously not enough in the sump for the sharp corner. I think its triggered by a level sensor...not the fact the circuits are suddenly starved of oil o_O .
gaza1994
49
15
31
Scottish Borders
So do you think i have sufficient oil and shouldn't worry? - wasn't going round a bend, was going up a slight incline at the time.
BoomerBoom
782
289
If you've checked the oil level and the warning stays off then no worries. I've only had that warning once, when the oil level was very low anyway and driving for hours on the motorway.
If, however, it comes back again then you should get the oil pressure checked - particularly if the red oil pressure warning ever flashes while you are driving.
Damo H
4,707
2,817
Car Length In Front
Apologies if you know this (as you never know), but when checking the oil level, you're wiping the dipstick clean after its first removed. then putting it all the way back in before taking it out to check the level that way. It'll give a better idea of the level in the sump.
As other have said it maybe of been triggered due to some harsh braking etc. I'd personally top it back up and then check it after every run once its had chance to cool.
Shaady
167
25
What engine is it? There are different recommendations as to when you should check the oil dependant (I think) on the engine.
For my 184 its after the engine is up to running temperature, so I usually check it once I'm home after my commute, and recommends that it should be left for a couple of minutes after switch off to allow the oil to return to the sump (this might explain why there is more on the dipstick after a couple of hours too)
BillyCool
737
302
Leicestershire, UK
If you check your oil soon after switching off, your oil level will read a bit lower. Check it when the car is cold and all the oil that was effectively in the system has drained into the sump and that is why you get a higher reading later on.
My 184 low oil tends to come on around halfway on the dipstick and I just top it up a little (I keep a little bottle in the boot).
Think you need to check the car cold and make sure as suggested above that you pull it out, wipe it clean and then check it. Hard to tell from your photo if you've just pulled it out or cleaned and re-dipped.
gaza1994
49
15
31
Scottish Borders
Hi Guys,
When checking its pull out (giggidy) wipe clean and pop it back in and then check :)
I checked yesterday morning after the car had sat overnight, there was a smidgen of oil on the bottom of the dipstick.
The user manual does however state to check it when the engine is warm ... when i do that, its about half.
BillyCool
737
302
Leicestershire, UK
Hi Guys,
I'd just top it up a little and see how you get on.
andycupra
status subject to change
i'd trust the level when you have left the car 2 hours +.
if its low when you have left it overnight (on level ground) then respond to that. don't respond to the level you are getting soon after switching off when the oil has been pumping around all over the place and potentially giving you inaccurate readings.
Mr Pig
2,912
1,088
I always keep the oil at the top mark on the dipstick. It gives you buffer, lets you lose as much as a litre of oil without it being a problem. It has saved me. Lost oil on a car years ago but no harm done. If the oil level had been lower it might not have been a happy outcome.
Reactions: Damo H
Mar 17, 2025
12
My seat Leon 2014 1.2 petrol - have engine light one due o2 sensors - replaced both sensor and error won’t clear - today I got the oil check message on - checked oil and it was too low , added a one litre of oil and turn the on after 5 minutes and got smoke around the engine like burn !
oil is added lots not sure what to do?
Mr Pig
2,912
1,088
Sounds like the head gasket. Trip to a mechanic.
Reactions: sewar
Mar 17, 2025
12
I changed oil and filter on 10th April - before changing I got the message that’s say check oil level.
Now today 31/05 after 7weeks got another message for check oil level ! I checked the stick it was too low.
I top up around 1 litre to see how it goes.
Mr Pig
2,912
1,088
Keep a close eye on it. I fear you may not be out of the woods yet.
