Hi guys,
Anyone got experience diagnosing (and fixing!) a cylinder misfire? I have a 2014 Cupra Mk3, remapped (by Revo) to stage 1. I always use Shell V-Power.
Started a few months ago. Got the P0304 fault code, local garage changed the ignition coil on that cylinder. Spark plugs had been done a few months prior. It came back after a couple of months. Symptoms were chugging, rough idle, EPC and engine warning light. Took it to a specialist and this is what they did:
The fault came back after a month of them doing this, attached is the OBD read out of what it found.
Before I pay more for them to keep investigating, anyone seen this on their car? Any advice appreciated! Many thanks.
- Compression test which was all normal
- Removed and checked cylinder 4 top manifold
- Cleaned the injectors in ultra sonic tank
- Moved injectors and spark plugs btwn cylinders
