Some things I need advice on......
Sl1ced
797
404
Ok so sometimes when I pull away if I don’t drop my foot hard it will pull away to about 2k revs then feels like I loose a serious amount of power for a split second then back to normal is this normal? I’ve found it won’t do it if I Rev it a bit harder as I pull away.
Also when she’s cold and I first start it before it’s warm and the idle settles down I can see the engine rock ever so slightly intermittently suppose I’ve never payed attention before but thought I’d ask
Connor H
1,052
518
Essex
Something mine has done since I got it and more so with the mods is on partial throttle it basically dumps the boost, no idea why and it’s quite annoying. N249 is bypassed so
Reactions: Sl1ced
Sl1ced
797
404
Wow almost the exact way I’d describe it. It’s really off putting lol. Mine did it with the 249 before I deleted it but it’s definately more noticeable.
Connor H
1,052
518
Essex
From my reading it seems that’s it a bit of a phantom issue that many people have and there’s no real cause found. I went as far as replacing my actuator hose and a few others and left it. Like you said it never does it unless I’m light on the pedal. I’m not bothering with it unless it persists after a remap
Reactions: Sl1ced
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Could be many things - have you checked for any codes ?
It could be plugs - how old are they and are they the right type, coil packs - one could be breaking down under load a bit.
Could even be a sticky valve, injector or even a maf sensor....
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
It could also be a mapping issue where somebody didnt quite get the fueling/spark table quite right - this would be a factory issue and may explain why so many people are affected by it
Reactions: Connor H
Sl1ced
797
404
Plugs are brand new oem recomended units. Coils all been tested and ok. Although not under load.
No codes at all so strange
hombre_paulo
157
Ha glad to hear its not just mine. Always done it for the last 60k with and without a map. I`ve put it down to a quirk of the car. Doesnt seem to affect performance at all
Reactions: Sl1ced and Connor H
Sl1ced
797
404
Excellent lol, we shall just have to live with it. As a question of interest what engine code you guys got? Mines AUQ
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
When I said map i was meaning the map installed from the factory - wonder if it had a slight bug in it - I have a bam engine and that doesnt have that issue (many others mindyou but not that particular one !)
Sl1ced
797
404
Yeah it will be intresting to see if a map done by the likes of r tech badger or AMD will correct it
