Hi all,
I have a 2009 facelift FR, 2.0 TDI engine code CEGA.
Does anyone know which turbo I have?
It's a BorgWarner turbo. OE Part number is 03L253056C
If you need the actuator that's available separately as a replacement kit. Part number 03L198716A
I'm thinking my N75 is knackered, does anyone know the part number? Can't see it on mine
| 1.9 & 2.0 TDI Boost Control Solenoid - 1J0 906 627 B / 1K0 906 627 A |
Darkside lists this actuator as compatible with Garrett turbos only?
Actuator needs to be setup once installed IIRC?
Yea, I got mine from Darkside.
Yeah, it needs to be held at a certain vacuum level when setting the position of the vane lever on the actuator rod. The proper replacement procedure VAG detail says to also verify the position sensor voltage but I think that's a belt and braces measure. The voltage on mine was exactly where it was supposed to be when I checked it.
You need two special tools to do the job too. A deep socket with a cutout and a banana shaped spanner but there's loads of kits of these on eBay, etc.
It is an awkward job to do in situ though.
I've just checked my parts invoice from when I changed mine in 2017 and that's the part number I bought but checking availability now it has been discontinued and replaced by 03L198716L
It's definitely the one for the BorgWarner / KKK turbo though.
I'm confused. Darkside are showing that part number as for bi turbo, the one I found on their website that will fit my engine (CEGA 170) is https://www.darksidedevelopments.co...Ex3ftxMZdsiLsmQwAKMEVKcuQs5WwD-gaAiZfEALw_wcB which is a different part number
ThanksDarkside supplied and installed a new actuator for my CEGA 170. Like you I also had a burst diaphragm so could hold no vacuum on the actuator.
From my receipt this is the part:
Electronic / Vacuum Actuator for 2.0 16v TDI CR Engines (Round Port)
Darkside Developments is a UK based diesel tuning company, specialising in VAG (VW, Audi, Seat and Skoda), BMW, MINI & Porsche Diesel Vehicleswww.darksidedevelopments.co.uk
Don't suppose anyone has a link or part number for the spare parts kit?
The 1 mentioned in the fitting guide, with the new bolts etc
