Starting Problem 2.0 16v
justinwhitehead
My coordy is not happy, she wont start, when I turn her over she seems to catch/spark for a second then just cuts out???? I checked the fuel pump and it whirrs when the ignition is switched on so I presume its ok, the leads and plugs seem ok, sprayed all connections with WD40 but no luck??
Has anyone got any suggestions before I have to get a mechanic out and pay a small fortune.....???
Thanks,
Justin.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
sounds like the immobiliser if it starts then cuts out after a second
sort of a brummm-------- dead
got another key ?
londonibiza
I agree check the key / immobiliser had the same when with the ibiza same symptoms I ended up checking everything ignition related and fuel related then next day tried the spare key and it was ok!!!!!! :confused: :confused:
justinwhitehead
Dont think it can be the immobiliser, had the factory one disconnected when I had my CAT 1 fitted, when the immobilisers on it wont even turn the engine or put any electrics on....?
Im getting a spark from the plugs so I think it must be fuel related, the pump seems to be working so perhaps its an injector or blockage problem.
Gonna do some 'Taking things apart tomorrow' and have a look.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
factory one is passive so no deactivation or activation required don't mean the alarm do ya ?
standard immobiliser (in key passive) will reveal symptoms exactly as you have described when not coded or not working
seen any 4mm*8mm blocks of plastic lying about lately ?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
cordobabrendy said:
lol daz mine fell out when i dropped my key once, glued it back in and worked fine!
ye will do mate - nowt to em really - seen em go through a washing machine fine as well :redface:
londonibiza
Or u play about with your key loose .....it then realise a week later that you dropped it in the house after the wife has cleaned the house a few times....
Seat ask at least 60 - 70 notes for a replacement key
londonibiza
Standard immobiliser lets the electrics come on and it appears to let you start....
just doesn't let the engine start and run....... not sure if it cuts the fuel pump or cuts the ignition circuit.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
fires up dies immediately - immobiliser most likely (try spare key if possible)
wont fire at all - check dodgy alarm first - never know
fuel is ok - check coil/cap/rotor (coils common specially when hot)
spark ok - check fuel pump/relay
no turn at all ? - battery flat probably :)
poor running cold / fine warm - temp sensor in thermo housing 4 pin usually
run ok cold / crap when warm - same as above
usual checks - just dig em out logically see if it helps
add to this various engines have other common faults like flywheel sensor (16v) etc etc
all good fun huh :):):)
cordoba RS
sounds like your imobiliser
Thanks,
Justin.
[:@]:censored:[:@]
my car will do the same if I dont use the imobiliser key first, it depends what imobiliser is on it of course but thats your buisiness, hope this helps as thats exactly wot mine does and I aint got no problems, it might not be this though, if not sorry an nice car.
