georgehedges
Hello,
Does anyone know where I can get replacement bolts for the brembo 4 pots on a Mk1 cupra R? Mine are pretty rounded and want to get them replaced before they go.
Do the bolts have stress grade numbers stamped on them?
If your replacements match and aren't chinesium or indium knock offs you should be OK.
link for a guide explaining how the stress grading works.
For a handle on the N/mm2scale, 250 would be soft steel, 500 is construction rebar, 2500 would be piano wire.
Hello,
Hi, the best place to get good quality bolts at a reasonable price is your local Engineers supplies , do a google search and go to the place with your bolts and they will be able to match them up
