Will they fit? (Alloy wheels for winter)
Aug 5, 2021
Hi,
I have been offered some alloy wheels, and I’m wondering if they will fit.
Can anybody tell if they will fit, or how I can check it myself?
Is it just to try out mounting them, and if they fit, it’s good? Or is there something else I need to check?
I have the Formentor VZ Hybrid 245 with the standard 19” wheels (245/40R19) and standard brakes (not brembo).
I haven’t been able to find the acceptable wheel dimensions for the Formentor 245.
The wheels I have been offered has the following dimensions:
7,5Jx18H2-N
ET49
225/45R18
Thanks in advance.
Jaco2k
AWD FTW
Mar 11, 2018
1,048
643
Tampere, Finland
www.youtube.com
Hi,
7,5Jx18H2-N
ET49
225/45R18
Thanks in advance.
ET is a bit on the low side - might be they catch the brakes.
Original wheels are ET40, so a ET49 wheel will be 9mm closer to the caliper.
Also, the tires are completely wrong, they are too low profile/too narrow, which means your speedo would be off.
Reactions: BBlachi
Deleted member 131219
This website is usefil in calculating whether wheels and tyres will fit your car. You also need to check the centre bore (the size of the hole in the middle) and the bolt pattern, known as pitch circle diameter (PCD for short).
