Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
What year of car?
Yes everyone refers to the MK7 Golf when referring to the MQB platform which our MK3 Leon's share.Well, it specifically sais that it fits Seat Leon 2017, is that right?
If not, then i got scammed by the seller, not intentionally though becouse the guy is par exelance but the outcome would be the same.
Not to tell that it has passed half of the planet to come to me.
Before i ordered it, i explicitely asked the seller if it fits my car, he didn't answer anything directly but never said it doesnt (i sent him the same print screen as you did). I told him also to send it if it fit my car.
Also, i must say that my shifter doesnt look like that on the first picture, with that black plastic, but more than like the second one.
Anyway, seems extremely hard to come to that part and to change it. Unfortuntelly, i couldnt find anyone to deal with it here and i barelly will.
P.S. My car is not an MK7 but MK3.![]()
I found my linkage ends are not too bad - my car is on 100,000+ miles.Ok, i'll ask him and let you know.
Regarding linkages, yes, i intend to do the alignment and change of cable linkages ends.
One mechanic told me that it might reduce the problem significantly.
Unfortunatelly, that also is a pain since it is pretty unapproachable.
You need to remove your air box. Then you can see your 2x cables attaching to 2 levers on top of the gearbox.the small white slip yoke and plastic lever
What is this exactly ?
Also, how did you inspect your gear ends ? Moved them to see if there is a slack / air in it ?
