BradleyH
(Used to be BradsterSwagDog but then I grew up!)
Jan 5, 2018
52
19
Chesterfield, Derbyshire
Good morning, all.
I am wondering if someone can help me with my pre retrofit thoughts, I've been lucky enough to find and purchase a 2019 Seat Leon FR steering wheel complete with loom and air bag.
I roughly know what I am doing to make the paddle shift retrofit work, however I had a train of thought that has made me question something, for context I have a 2019 Seat Leon Xcellence Lux, and on this trim level it has keyless start, now I know that when the car is completely switched off the steering wheel puts itself into locked position by itself no need for the usual turn of the wheel to engage a steering lock. I did see a guy dressed in a shirt and tie do a paddle retrofit in a 2012 Passat on YouTube and he claims you don't have to disconnect the battery as the wires are essentially failsafe I do not remember what he said, but I do know that probably best course of action is to disconnect the battery, which brings me to the point of this post, if the battery is disconnected in my mind the receiver that detects the key to unlock the steering wheel when you want to get in and drive is no longer able to detect a key therefore not allowing for the steering wheel to be turned whilst the engine is off, do I have a flaw in my thinking or is there a way around this? or maybe even the guy with the 2012 Passat was correct and disconnecting the battery is unnecessary after all the thing didn't go off in his face when he did it.
Any information or insight will be very helpful and when it is complete I will have the airbag from the Leon FR available to a good home if anyone needs one for a small price.
Thank you
Bradley
ignition on
ignition off
battery off
Cheers guys! I will have some work for you eventually with retrofitting a ‘Seat Sound’ system into the car.
My other little question, I’d never actually bother with doing this but because I will have the new wheel off the car for a little bit before I get to doing the retrofit, do you know of any paddle extensions that are similar to the Racingline ones I.e ‘bolt on’ ones and not clip or stick on ones that aren’t Racingline money? I saw some for like £33 but they’re listed as VW ones and copilot is telling me it won’t fit, which I accept generally but worth asking a real person I guess 🤣
The wheel I’ve bought is from a 2019 FR if that helps at all images can be sent also if that’d be definitive?
I'm not sure on paddle extensions sorry, it's not something we've any experience with aside a comically large 3D printed set we made a few years ago 😆
Oh good god 🤣 well either way thanks for the info on the proper protocol for the steering wheel, I’ll just have to keep looking for paddle extensions, I mean I honestly would never do the mod because it is a lot of effort, but since I have a wheel not on the car I am tad bit more inclined 🤣
I replaced the original paddles with magnetic paddles, and they are a blast. You do need to take into account that every gear change is a clicky noise. Costs about 70-90 euro if I remember correctly
More pics:
AP1GczMugieLLU1Rh8jTOwCCShFAXTdaLLzJUg0lHFjMEup2YqwfbIq7TnaHMD7xhshNink9z39pl6ObFrgG5T3MOCgqIXja_TppSZrM7cn9YTEfgKhwAWKB5rS6b4UHV9H70-ofE5OA_hdQMXgMzC-HBQLWrw=w720-h1280-s-no-gm
AP1GczOwk6LaEstoi1dKsfARj1Ls_QW0r8QAytLDQbi_WiowfxZGFt4YZqPVAyz5XtllLte-T3T044wJB9GYX-zt49f1zbiZPq0fF8lxTI2pnxRLwuXYmRcTWkzZMEPUylIz3-f7GGcSrM-BaQMR8gDX5C2vgw=w1920-h1080-s-no-gm
AP1GczMoU8DUICzoJkQEC-U7qaGCgwASirlZzH47qAcznfrNR34WEWm5raFGrOI6v86yUPNzflKVA6scylovO8tNtAIuuiCShM8fgUtagEr0HX57iRuc6EXuOJgni6bZqsFRJtHERENyywTq8fpEMvxBjdyfAg=w1920-h1080-s-no-gm
Reactions: BradleyH
More pics:
they do look nice, do they do it in silver? Would like to match the dash is all? Do you remember where you got them from?
Good morning @East Yorkshire Retrofits , I did the retrofit yesterday, no problems at all, didn't require coding either just worked straight away, only left with 2 faults in the OBD log but they predate the retrofit. However I have noticed the wheel is slightly facing towards the right, do you think I could have just not lined up the shaft and the wheel 100% correct? I was ultra careful not to rotate the clock spring behind it and I am not hearing clicking or anything of that nature when I turn the wheel and I am not noticing any resistance points when turning the wheel in either direction, so I am just hoping the spline is slightly out. Only thing I do notice is when I am stationary and start to turn the wheel full lock there is a slight and quiet wurring noise but I am 99% sure I am just noticing something from just being hyper aware after the install.
You'll likely have refitted the wheel one spline out of alignment :)
Cheers guys, I plan on sorting it out this afternoon :)
I do have a question to ask you based on something you either used to or still do sell, the "Touch climate control" do you still do them? if so how much? I think on your website it says facia only is all.
I think we have one fascia left, I’d need to check if it’s facelift or prefacelift. We aren’t producing anymore
The climate panels themselves can be found in Tiguans and Atecas amongst a few other models
Okay thanks for the info, if you wouldn't mind checking the availability and seeing if you do have a facelift version I'd appreciate it, do you know what the part number is for the climate panel? and what else is needed?
Good morning, all.
Thank you
Bradley
I have the same car and the same problem. How did you turn the wheel to get the clips off?
