Things I have discovered about the car.
jcbmally
Dec 26, 2013
1,272
550
Cybertron
You can set the the temperature in the car using the voice command button on the steering wheel "set the temperature to 22 degrees". If you leave off the "degrees" the system gets confused. This only changes the temperature on the driver side. I will experiment with the passenger side/ both later today. You can also change the radio station using the voice command button. "Play BBC Radio 2/4/6/Talksport/Jazz FM" all work well. Again, if you say "Play Radio 2" it gets confused. Getting there slowly...
Also found that “volume up” or “volume down” work as well, class, who needs knobs and buttons :cool:
Reactions: CupraNewboy
Oct 8, 2021
77
57
Discovered these two today
1. If navigating via Apple Maps, the directions and next turn appear on the instrument dial and the cars native satnav map (depending on your instrument view). It doesn’t appear if using Google Maps (via Apple CarPlay).
2. If playing music (only tried with Apple Music) and the passenger door opens, the music stops.
CupraNewboy
123
78
If you do the full data protection thing, go and get authorised at your dealer/ service centre (photographic ID required), you get full use of the app, including setting the temperature in the car remotely to a time you have set. My car is 100% petrol & not hybrid (some suggested this would only work for hybrid cars).
Kieran94
48
9
Can you screenshot a few examples of what’s unlocked with the full access of the app please?
AndyCupra93
296
127
That’s very interesting, and as far as I’m aware not advertised? The only thing I thought that affected was the ability to lock/unlock via the app.
Will it remotely start the engine to run the climate control?
Agnes.Surrey
770
420
Surrey
It's just ventilation and it won't do much, at least when it's cold. I was hoping it will help with defrosting windscreen, but absolutely no difference. You don't need any special authorisation to run ventilation function.
Hizzards
102
74
Some countries have an Auxiliary heater (it’s in the manual) so they could be somewhere other than UK.
jcbmally
Dec 26, 2013
1,272
550
Cybertron
Has the ventilation function on VZ Edition but it isn’t on the V2 as far as I know. Not on the app but I haven’t checked in the car TBF.
AndyCupra93
296
127
The poster mentioned that it allows you to set the temperature.
Seriously?
1,473
1,065
Clever, no doubt. But given that it's somewhere in the region of your right knee, I'm not convinced it's that much help 🤔
Napmasterflash
260
156
When you stop the car, if you turn the engine off it goes into park and puts the handbrake on automatically. In my previous car I always forgot to do the handbrake so quite useful.
Sent from my Pixel 5 using Tapatalk
77
57
When you stop the car, if you turn the engine off it goes into park and puts the handbrake on automatically. In my previous care I always forgot to do the handbrake so quite useful.
I don’t seem to get that and constantly forget to place it in Park. Never had it automatically put the handbrake on either. Interesting.
Tell
I must turn that on
Yeah they must have moved the switch with the coloured lights on it (red and green) as per the Ateca onto the main infotainment scheme like all the other controls in the Formentor / Leon 4. I've knocked mine once and wondered why it rolled when I parked... only once in 5 years 😂. It works well in a DSG.
Napmasterflash
260
156
Not really a discovery but at night the interior looks beautiful lit up. The exterior lights also look top, my 6 year old son is loving the Cupra logo on the floor.
Hopefully by Christmas he will realise he can't stand on it!!!!
Reactions: jcbmally
