hello everyone
i need to active speed limiter on seat tarraco, does it required any sWap or just coding ?
thanks
thanks
this is dose not work as i have virtual dashboard and the button in the steering is not workingHmmm I'd be careful when I was looking at this a few years back people programmed speed limiters with VCDS and it became a permanent change, no going back. If you are not talking about coding could be this:
It's a facility I don't use on my Ateca. Think it's the upper limit of ACC so you dont lock onto a speeding car and also speed. Going to be in the manual, the button fumbling adjustments of ACC.
i just want to active it, some people told me it's required code belong to vin and some other people said it just coding and adaptation but no one give me clear answer how to do itPersonally I don't use ACC... had it activated and enjoyed dashing up behind cars on down hills into roundabout where I'd normally use engine braking but those in front were in convoy wearing their disks out and risking stone chips by following too close. I got use to spotting cars using ACC in outer London. All too close racing in convoy.
How it works is in the manual. Fumble with the switch. Indexed into the pages and on. It's all in there, the Ateca ACC control for the pre face lifted.
Adaptive Cruise Control Acc - Seat Ateca 2016 Owner's Manual [Page 199]
Seat Ateca 2016 Manual Online: Adaptive Cruise Control Acc. Introduction Detection area. Fig. 175 ››› table on page 2 The adaptive cruise control (ACC) is an exten- sion of the normal cruise control system ››› (CCS) . The ACC function allows the driver to estab- lish a cruise speed of...www.manualslib.com
Another stalk other than the left and right indicator stalk... don't wander my hands down there... try not to. That leaver is the same as the one shown in the video. I got that leaver. I seem to recall if you have lane assist it's reflected in the stalk. So there are two different styles of third stalk, Rings a bell. There use to be murmers about it on boards. Now its big buttons for traffic assist....
Those paddle on a DSG if you hit by accident on a round about the quick solution to get out of it is to grab the gear change, flick to sport and back out.
I'm a luddite with the boy racer tech as far as ACC is concerned, traffic assist and lane assist. Got them, don't use them. Drive the car instead
Some VAG stuff goes beyond VCDS coding like the electric tailgate at the last check on the Ateca conversation on that one if it's not programmed into the car at build then it's not possible although perhaps if you rip enough out and pair it up with a car that has it, you might get it to work. Might be one of those.
unfortunately yes there is no tarraco in Egypt have ACC, just only cruise controlSome VAG stuff goes beyond VCDS coding like the electric tailgate at the last check on the Ateca conversation on that one if it's not programmed into the car at build then it's not possible although perhaps if you rip enough out and pair it up with a car that has it, you might get it to work. Might be one of those.
Are you really saying that Tarracoes in Egypt don't come with ACC.
Well we can always as one of the boards retrofitter sponsors whether it's a no go area for a hobbyist @East Yorkshire Retrofitsunfortunately yes there is no tarraco in Egypt have ACC, just only cruise control
possible to get swap codes for it?Speed limiter, CCS, ACC & PACC are all SWaP (SoftWare as Product)
You can't enable with VCDS
Fortunately we can help![]()
I can see if there's one available for the speed limiter if you send me your VINpossible to get swap codes for it?
sent to you please checkI can see if there's one available for the speed limiter if you send me your VIN
is the vin support "speed limiter" swap code by default?I can see if there's one available for the speed limiter if you send me your VIN
Speed limiter isn't SWaP thankfullyis the vin support "speed limiter" swap code by default?
