1)Pre warm the car using the app before you set off in the morning....it will warm the interior,turn on the heated steering wheel and warm the battery do you get better range at this time of year. (Select climate and EV charging in the departure time area when setting this up)
Obvs the car needs to be plugged in to gain the benefits)
2)around town use either the sport mode to get regeneration of the throttle or set max regen in vehicle settings.
When I'm not doing purely town work I leave the regen on auto so it can coast too.
3)Charge as often as you can to get maximum range and mpg.
I plug in as soon as I'm down to 15 miles range in the gom when I'm at home.
4)Be gentle on the throttle and look ahead to anticipate the traffic to maximise the ev range (if that's what you are after)
5) Don't worry about having air con turned on,it uses very little electricity and using it stops the cars interior steaming up all the time (as some
Formentor drivers who turn it off are finding)
6) Enjoy the benefits of the sport and cupra modes,the car has excellent performance when it combines the ev motor and engine...don't forget it has GTi go when you want a little fun.
7) if you hardly use petrol and don't refill often,then consider using 98 Ron super unleaded...it doesn't rot the ancillary pipes like the new 95 Ron fuels so it's happy to sit in your tank longer,plus it definitely boosts the performance when you do need it.
