Luke S77
14
So, water ingress had totally borked my offside outer tail light and was able to get a replacement. Fitted and tested... rear light works, indicator works... but when i pull the fog light switch out... only the front fog indicator lights up and shows on the dash. when i check the fronts are on but at the rear it is only lit on the near side inner
I'm sure i remember the dash showing both fog lamp indicators lit and also the switch. Don't seem to be getting any info from the car saying there's an issue (like i did for the offside rear indicator, following the water ingress)
There is only one fog and one reverse light so don't worry if "both" don't light up.
Similarly, there's no indicator on the dash for the rear fog. I think the fog light on the switch itself should light up though.
Reactions: Luke S77
Man, I was sure I'd seen it on the dash. And when you change the light you think you've done it wrong.
Many thanks for the info
I thought the rear fog was on the offside cluster and reverse lamp the near side? Offside fog so folk don’t think your a motorbike and not leave enough room.
Assuming it's a UK spec car, then you're absolutely right(y)
i can say for sure that it was the near side inner tail lamp that was lit when i switched the rear fogs on and not lit when i switched it off
didn't test the reverse light
i can say for sure i mixing up offside and nearside too ?‍♀️
basically, the rear fog lamp that lit was on the right
Just been outside(in the rain) and took this picture, not too clear in daylight but confirms my thoughts.
yep. this is the side my fog lamp was on. must remember... nearside=curb offside=middle of the road
I think now it's usually said L/H and R/H side as viewed from sitting in drivers seat, should be no mistakes then as it will be the same for LHD and RHD cars.
