Front Suspension Replacement
Nov 28, 2019
Hi,
I've recently replaced my front suspension struts on my Leon MK3 FR (150) TDI.
Since then the ride is really uncomfortable. It jerks forward/backward randomly and shakes (not vibrating) when driving, and you can feel every bump in the road. You can feel it through the seat. It's not noisy, but when I go over bumps it feels too hard. I've had a mechanic have a look at it and he said he can't see anything wrong. He thought it was a buckled wheel, which I did have but that hasn't solved the problem. The struts I fitted were Ridex from AutoDoc. Has anyone used any parts from them and thought they were rubbish, because I think the suspension is not fit for purpose. Does anyone know what is the original brand of suspension VAG use? I put Sachs struts on the back and they were fine.
Does anyone know why there is such a difference in price/so many alternative brands for aftermarket parts. I wish I had bought the parts from the dealership now.
I've owned the car for 5 years and it used to drive really smooth and handle well. But now it is just awful.
SuperV8
1,872
941
Hi,
Have not used Ridex dampers - but I know they are a 'budget' brand.
some things i'm afraid you get what you pay for - dampers for me are one (along with brakes & tyres) - technically very complicated.
Seat have something like 30x variations in part numbers depending on the exact spec of the car.
Sachs do make the Seat OE dampers - but Sachs aftermarket are NOT the same as the Sachs Original Equipment.
I think they have 2x versions like sport & normal for their aftermarket dampers vs 30x for genuine OE!
The OE dampers aren't actually that expensive (not including the DCC dampers!)
I'm sure you can return the Ridex dampers - but I think you'll only get the part cost refunded - not the labor!
Nov 28, 2019
Thanks for the reply. I thought the brake disks were bad, having 4 sizes to choose from.
SuperV8
1,872
941
Just to note:
Any bush that's horizontal needs to be torqued up when the vehicle's at normal ride height - If torqued up when the wishbone is fully extended in droop will wind the bush up. Not sure this will contribute much to your hard ride?
