May 8, 2022
Manchester
I have a 2021 Leon FR Sport eTSI.
After the car has been sat for a while and I start it, upon putting it into drive and setting off I get a message on the infotainment and it says changing vehicle settings. If I click cancel then the message goes and nothing changes however if I click ok then the drive mode might change, cockpit view may change and some other stuff.
Also, randomly the AC settings will default to 22c on both sides and force the A/C on. This doesn’t matter what it was set to previously.
This has only been happening in the past 2 months maybe less
To add to this, the car has had the 1896 OTA and this has not made a difference.
I ensure that I am always using the same key
Has anyone got any advice on this issue? Thanks
Think it happens when there's an issue with connect? As mine has done the same recently
Sent from my SM-N986B using Tapatalk
I have this message ALWAYS 2-5 minutes after starting the car.
Once I managed to get rid of it - clicked OK, didn't change anything in the settings until the next ride and it stopped showing up.
However, it is failing now.
I read somewhere that it was due to the lack of synchronization between the profile saved on the seat server and the one in the car. It connects to the Internet, downloads the settings from the server and tries to replace them in the car.
It is supposed to be a convenience for those who have several cars, then they have the same settings in each of them. But for people who have one car the profile it should be local.
This has started reoccurring on mine, hadn't come up for months
Hey it works. When the message pops up, click OK. Do not move anything in the car's settings until the end of the drive. I didn't change anything during the next tour. On the third route, I set what I want and since then I have not seen the message.
I've been getting this regularly recently and tried the above. The fix seems to last one (perhaps two if I'm lucky) trip/s after :(
If it would say it before you've been driving for 5 minutes, I wouldn't mind so much.
The only consistent change if I do let it change the settings is up to 22c and speed 2 on the aircon and to lose the playlist.
Random other changes are drive mode, dashboard settings and satnav locations.
For what it's worth, I'm still apparently on 1790 but does anyone have any other trickst to try please?
