I've seen theses about allot is that what you mean https://www.ebay.co.uk/itm/17494321...l:Leon&hash=item28bb6d9281:g:if0AAOSwz~paLB8-Do you hear the fan turn?
Most cars have a resistor to slow the fan down so if the fan turns only on the highest speed it's the resistor (more specifically the thermal fuse across the resistor) that is dead.
Yes that's the resistor.I've seen theses about allot is that what you mean https://www.ebay.co.uk/itm/174943212161?fits=Car+Make:Seat|Model:Leon&hash=item28bb6d9281:g:if0AAOSwz~paLB8-
seen them cheaper as you can get them without that housing not worth skimping on the pollen filter, if not hit the miles for changing its worth hoovering out on oil change while inspecting if its not that bad, use to change mine every year seem some clogged one though just depends on area you are inYes that's the resistor.
that's good too know as i can solder its getting the right one though , i had a right nightmare getting a replacement power switch on my sub as that was custom, sorted thoughYou can repair the resistor for a couple of quid, the thermal fuse is cheap but you need to be able to solder
