Same on the V2 1.5. No engine insulation. Guess it's based on size of the engine, unless anyone has different?Any of you gents here with the Hybrid version: do you have the engine hood insulation installed?
I was wondering if the "naked" hood is a standard feature or if it's country dependent.
Yeah, mine didn't come with it either do I bought one and fitted it myself. Reasonably cheap and dead easy to fit. Looks much better too.Any of you gents here with the Hybrid version: do you have the engine hood insulation installed?
That is one full engine bay. ?Yeah, mine didn't come with it either do I bought one and fitted it myself. Reasonably cheap and dead easy to fit. Looks much better too.
View attachment 38809 View attachment 38810
Indeed, it looks as if the car was not delivered incompletely built...Looks much better too.
I bought mine from Here (one of the forum sponsors) but they've gone up a lot since.Indeed, it looks as if the car was not delivered incompletely built...
Do you have a part code for that insulation? Does it also come with the plastic buttons that hold it in place?
Thanks!
Just fitted these, not too bad needed a little double sided tape and a better hex key than the one supplied. View attachment 38112 View attachment 38113
The Leon Cupra I bought had these already fitted by the previous owner. I had to remove em as they kept getting in the way when indicating n using cruise control etc. Much better for me now.I ended up getting these same ones. I didn't need double sided tape though, but I made sure to take my time while screwing in the screw.
I can see why these might not be for everyone, i don't like line of sight to the cluster being obstructed. However, i'll probably know after a month whether these are for me for the long term.
I had also purchased a sunglass holder to replace the grab handle on the driver's side. I am yet to be successful in removing it to replace it.
I'm hoping that I don't have that issue in the Formentor.The Leon Cupra I bought had these already fitted by the previous owner. I had to remove em as they kept getting in the way when indicating n using cruise control etc. Much better for me now.
Once done, I'll upload a pic of the final result.
I have found (procrastinating at work) this image - and from various YT vids, you'll have to really pry on the clips.Please do, I also struggled with getting the grab handle off.
I ended up buying the tool to remove the handle as i couldnt manage it with just two hands in a contorted position.I have found (procrastinating at work) this image - and from various YT vids, you'll have to really pry on the clips.
Thanks, I’ll give this another go at the weekend.you'll have to really pry on the clips
Thank you, Kindly.I ended up buying the tool to remove the handle as i couldnt manage it with just two hands in a contorted position.
Amazon Handle tool
Happy to lend you the tool if youre nearby (im in south essex)
Im also procrastinating at work today
Unfortunately, I haven't found an official part.Is the sunglasses holder an official accessory? If yes, what’s the part number?
A link to where to purchase in the uk would also be good if possible!
